About renewal using eab-key
My domain is: umich.edu
I ran this command: sudo certbot certonly --standalone --non-interactive --agree-tos --email email-id --server url --eab-kid xxxxxx --eab-hmac-key yyyyyyyyy --domain xyz.umich.edu --cert-name xyz.edu
My web server is (include version): no webserver
The operating system my web server runs on is (include version): Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
My question is , I don't have a webserver on my machine . I ran the above command and used the eab-kid and key in command line to request the certificate . Should I explicitly mention the eab-kid and eab-hmac-key in the renewal conf file for renewal to happen or does certbot know the options used in command line during renewal .
Thank you
EAB credentials are only used when your account is being registered.
To satisfy yourself that your specific renewal would work try
sudo certbot renew --dry-run --cert-name xyz.edu
Well, dry-run might be misleading in this case, since it will use Let's Encrypt's staging server, even though the "real" cert is using some other CA. It'll check whether the server is accessible and such, but won't confirm that the production configuration is using the EAB settings.
Oh right. I think by adding --server url after --dry-run it might work with their CA
Dry-run fails with a firewall port 80 error ( there is no staging server I guess ? ) . But this command works , **sudo certbot renew --force-renewal --deploy-hook /tmp/script.sh ** . Is this good enough to ensure that renewal works without the eab settings in conf file ?
No, Peter made good point that --dry-run sets the Let's Encrypt Staging server. You look to be using some other CA since you used --server in your first post. And, LE does not require EAB :slight_smile:
As for --force-renewal, be careful to only use that once and not for your regularly scheduled renew. You'd end up getting a cert each time which might cause problems with your CA.
And, I'd avoid using --deploy-hook for renew command because that should already be in your renewal profile from your first command. See the /etc/letsencrypt/renewal folder for these profiles
I'm not sure my --dry-run suggestion works as-is with alternate CA. I know there was some sort of trick about adding --server URL but not sure if that actually works with --dry-run or was some other context.
Update: I found a previous thread which talks about --dry-run and --server. Should work
I think you've got the right idea, @MikeMcQ. A dry run is just an easy way of setting the server to staging and not installing the resulting cert. One can do that manually with any CA using certonly and --server STAGING_URL without using --dry-run..
Or pay another $ 100 for a useless duplicate certificate :exploding_head:
Yeah, but --dry-run ensures the certs won't overlay your "non" dry-run certs, as you note. At least it does with regular certbot renew but now I am not certain it does when adding --server-name after --dry-run. My original thinking was that it did which is why I suggested it.
But, using certonly with --server Staging_URL will overlay any prior cert. With LE, at least, Certbot has some protection and sometimes need --break-my-certs to do that. I'm not sure all of the cases this is needed. If Staging_URL is an actual trusted CA then this doesn't matter but if it was an actual test CA system it does.
I regret suggesting --dry-run with alternate CA. I don't fully appreciate all the quirks that can result. Requires deeper evaluation probably on a per-CA basis.
And it doesn't help that many CAs don't have analogous staging environments like Let's Encrypt does. (I think Google and Buypass Go do, but I don't think there are many others.)
Haven't ever seen anyone use that in the field. I believe it's used with this, which should clear up some mysteries. Without the --break-my-certs option, I believe --staging does not save/overwrite the certs. :slightly_smiling_face:
--test-cert, --staging
Use the Let's Encrypt staging server to obtain or revoke test (invalid) certificates; equivalent to --server https://acme- staging-v02.api.letsencrypt.org/directory (default: False)
--dry-run
Perform a test run against the Let's Encrypt staging server, obtaining test (invalid) certificates but not saving them to disk. This can only be used with the 'certonly' and 'renew' subcommands. It may trigger webserver reloads to temporarily modify & roll back configuration files. --pre-hook and --post-hook commands run by default. --deploy-hook commands do not run, unless enabled by --run-deploy-hooks. The test server may be overridden with --server. (default: False)
https://eff-certbot.readthedocs.io/en/latest/using.html#certbot-command-line-options
As you mentioned , the staging environment is disabled for Incommon in my organization . As an alternate to see if the renewal works and also to check if deploy script works , without mentioning the eab key in the conf file , I tried sudo certbot renew --force-renewal --deploy-hook /tmp/script.sh. It's a test server I tried and just wanted to make sure this is valid .
Per my post above with certbot syntax, you can always point the dry-run at the production URL with --server and get all the testing benefits of a staging dry-run except with the lower rate-limits of production. It's unorthodox, but can work in a pinch.
The only benefit of this I can think of is that --dry-run disables existing cached valid authorizations and thus will always require a new authorization.
Depending on the CA used, using a production API might cost you money though.
It also won't save the acquired certs to disk and provide other such testing functionality.
I suppose what I'm saying is that one can use dry-run independently of the staging server.
Sure, but, if you are using a production --server with --dry-run why are you concerned about overlaying prior certs?
Let's just say there's a niche application for it when it comes to these kind of special circumstances.
When you're testing configuration changes and such, you might not want to replace certs and restart web servers.
sudo certbot renew --dry-run --server XXXX
Processing /etc/letsencrypt/renewal/r0-mysql.umich.edu.conf
Simulating renewal of an existing certificate for r0-mysql.umich.edu and r0-db.umich.edu
Terminated
This is what I got back from the dry run and looks like it worked .
