since ifastnet announced they wont support free ssl on free hosting plan many users are getting error such 403 or 404. so here a idea for to install first enable your cloudflare from control panel then once its done. you might get universal ssl then go to sslforfree.com and upload the 2 files for verification then ssl certficate will generated copy it and paste it in ssl/tsl option in controll panel as it is uploaded disable cloudflare after some time you will see your certificate installed. if still confused reply to these forum i will upload video on this
Hi @noel
I’m going to modify the title (to make it accurate).
Hope you could organize the content… (Style, divide paragraph etc…)
Thank you
