403 Unauthorized/forbidden when using certbot-auto renew --dry-run
ravenrosecomputing.com
/root/bin/certbot-auto renew --dry-run
Attempting to renew cert (ravenrosecomputing.com) from /etc/letsencrypt/renewal/ravenrosecomputing.com.conf produced an unexpected error: Failed authorization procedure. ravenrosecomputing.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://ravenrosecomputing.com/.well-known/acme-challenge/EYtLQeo8hxR2myaADKHayJopLaukQcxu5X7B0MDZcEY: “\n\n403 Forbidden\n\n
Forbidden
\n<p”. Skipping.
/etc/letsencrypt/live/ravenrosecomputing.com/fullchain.pem (failure)
apache 2.2.15 built 6/19/2018 with Mod-Mono support
CentOS release 6.10 (final)
1&1 Ionos
Yes
No
0.30.2
Hi @kosovmd
if you want to use http - 01 - validation, Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks this file.
But there is no access ( https://check-your-website.server-daten.de/?q=ravenrosecomputing.com ):
198.71.51.142 403 0.264 M
Forbidden
http://www.ravenrosecomputing.com/
198.71.51.142 403 0.267 M
Forbidden
https://ravenrosecomputing.com/
198.71.51.142 200 2.653 B
https://www.ravenrosecomputing.com/
198.71.51.142 200 4.590 N
Certificate error: RemoteCertificateNameMismatch
http://ravenrosecomputing.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
198.71.51.142 403 0.270 M
Forbidden
http://www.ravenrosecomputing.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Forbidden
Port 80 is open, this is good. But there is a http status 404 (Not Found) expected, not a 403 - Forbidden.
So change your permissions.
You should allow the /.well-known/acme-challenge/ request to pass without requiring authentication (403).
This worked. Had to comment out the following line in my httpd.conf file:
Options FollowSymLinks
AllowOverride All
SSLRequireSSL
