Renew test is failing
My domain is: sandbox.installio.com
I ran this command:sudo certbot renew --dry-run
installio@sandbox:~$ sudo certbot renew --dry-run
[sudo] password for installio:
Processing /etc/letsencrypt/renewal/sandbox.installio.com.conf
http-01 challenge for sandbox.installio.com
Enabled Apache rewrite module
Waiting for verification…
Attempting to renew cert (sandbox.installio.com) from /etc/letsencrypt/renewal/sandbox.installio.com.conf produced an unexpected error: Failed authorization procedure. sandbox.in stallio.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://sandbox.installio.com/.well-known/acme -challenge/__5JUxTZjoyTfjbGWWEXCfWq7gBfziVuBKC82s2DtvE: ā€œ<html lang=ā€œenā€><meta charset=ā€œutf-8ā€ /><meta content=ā€œIE=Edge,chrome=1ā€ http-equiv=ā€œX-UA-Com patibleā€ /><meā€. Skipping.
/etc/letsencrypt/live/sandbox.installio.com/fullchain.pem (failure)
** DRY RUN: simulating ā€˜certbot renew’ close to cert expiry
Server version: Apache/2.4.7 (Ubuntu)
Server built: Apr 18 2018 15:36:26
Ubuntu 14.04 trusty
I am self-hosting on AWS
Yes
I am not using a control panel
The apache2 config file, created by certbot included the original config file, but did not delete it. I removed the included file, and the dry run worked this time around
I get a 401 unauthorized error when accessing the /acme-challenge/ folder:
root@system# wget http://sandbox.installio.com/.well-known/acme-challenge/test.txt
–2018-11-01 23:04:51-- http://sandbox.installio.com/.well-known/acme-challenge/test.txt
Resolving sandbox.installio.com (sandbox.installio.com)… 54.210.91.252
Connecting to sandbox.installio.com (sandbox.installio.com)|54.210.91.252|:80… connected.
HTTP request sent, awaiting response… 401 Unauthorized
Username/Password Authentication Failed.
