Auto Renewal/Dry Run not working
My domain is: kendallsecurity.ddns.net
I ran this command: ./certbot-auto renew --dry run
Attempting to renew cert from /etc/letsencrypt/renewal/kendallsecurity.ddns.net.conf produced an unexpected error: Failed authorization procedure. kendallsecurity.ddns.net (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://kendallsecurity.ddns.net/.well-known/acme-challenge/EKLvQ7gEQiAq8Xcc4Efru1GZ_7egdbdwk6N2k5JodZE: "
Document Error: Not Found
Access Error: 404 -- Not Found
". Skipping.
------ However, these commands complete fine.----------------------
./certbot-auto certonly --webroot
./certbot-auto renew --force-renew
My operating system is (include version): CentOS6
My web server is (include version): httpd
My hosting provider, if applicable, is: Myself
Do you had redirections from port 80 to port 443?
If yes, try to start web server only on port 443 and try renewal.
This was my workaround yesterday, “cerbot renew” not worked but “cerbot renew --dry-run” yes.
I restarted the web server with only the server instances on port 443 and it worked.
Hope this help
Yes, 443 and 80 are open…
Thanks…
Looks like ./certbot-auto renew --dry-run worked. I must have needed the “-” between dry and run.
Thanks!
