Your system is not supported by certbot-auto anymore
Hey guys, not exactly dev related but I'm struggling with this and I need some help.
Tried to renew SSL certificates from LetsEncrypt today, and I was met with Your system is not supported by certbot-auto anymore.
I followed the instructions on Certbot Instructions | Certbot, but whenever I run sudo certbot --nginx I still get "Your system is not supported..."
I assume this is because the certbot commands still points to my old installation, but I've removed certbot with sudo apt-get remove certbot so what's happening here?
(If not obvious, I'm a complete newbie at this).
Hi @vdhnat, and welcome to the LE community forum :slight_smile:
You should completely uninstall (not delete) any previous version(s) of certbot/certbot-auto first.
Did you check that certbot-auto was uninstalled?
