Please my website energymediagroupghana.com is facing Connection is not Private issues, I contacted My Host (Godaddy) and they said I contact you because "It is to troubleshoot on the SSL by SSL provider to activate SSL.".
I don't see any problem with your site. Your cert was just created yesterday and will not expire for 89 days. Your HTTP site properly redirects to HTTPS.
The screen image you show does not have any error. It is just telling you for the latest info you need to "clicking here". You can also check your server certs on other sites like this one which also says it is fine.
Can you show the screen that has the error about "not private" that you describe?
