Wordpress Site not loading with "took too long to respond" after installing SSL
My domain is: personaltanner.com.au
I ran this command: certbot --apache -d www.personaltanner.com.au
It produced this output: Which names would you like to activate HTTPS for?
My web server is (include version): Apache/2.4.41
The operating system my web server runs on is (include version): Ubuntu 20.04 LTS
My hosting provider, if applicable, is: AWS Lightsail
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.31.0
Hi @ndwyer, and welcome to the LE community forum :slight_smile:
HTTPS requires TCP port 443 access.
Please check your firewall and NAT rules.
[in your system and in AWS security]
Thank you so much @rg305. That was the issue.
For any Lightsail users out there reading this steps are:
  1. From the Lightsail console home click on the instance
  2. From the instance, click on the Networking Tab
  3. Under the IPv4 Firewall heading click on "Add Rule"
  4. From the Application dropdown choose HTTPS and it will auto-populate the remaining fields (Protocol=TCP, Port-443)
