WordPress: cURL error 60: SSL certificate problem via Really Simple SSL
My domain is: stopford.com
I ran this command: Checked Really Simple SSL's open tasks
It produced this output: The mixed content fixer could not be detected due to a cURL error: cURL error 60: SSL certificate problem: certificate has expired . cURL errors are often caused by an outdated version of PHP or cURL and don't affect the front-end of your site. Contact your hosting provider for a fix.
My web server is (include version): Linux
The operating system my web server runs on is (include version): Linux
My hosting provider, if applicable, is: TSO Host
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): WordPress 5.81
Wordpress seems to use its own certificate bundle, which is located in wp-includes/certificates/ca-bundle.crt. Replace this file with the latest one, you can get it from the curl website: curl - Extract CA Certs from Mozilla
While you're updating...
Make sure the rest of the system also has the latest ca-certificates update.
