Wild card and www
web-wallet.com
sudo ./certbot-auto certonly --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns -d web-wallet.com -d *.web-wallet.com -d \*.web-wallet.com
all goes well
Ubuntu 16.04.6 x64
Digital Ocean
Yes
No
Command not found but i know it’s there… installed that way:
$ wget https: //dl .eff.org /certbot-auto
$ chmod a+x . /certbot-auto
$ sudo . /certbot-auto
Everything work without www i can put any subdomain name:
https://mommy.web-wallet.com
https://toto.web-wallet.com
https://letsencrypt.web-wallet.com
etc… but as soon as i add the www i get:
# Your connection is not private
Attackers might be trying to steal your information from www.mommy.web-wallet.com (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID
Thanks in advance for the help :slight_smile:
Hi @crashbdx
that's normal.
If you have a certificate *.web-wallet.com, it works only with subdomains. Not with subdomains of subdomains.
There is no
*.*.web-wallet.com
defined.
If you want to use the www.mommy.web-wallet.com secure, you need a new certificate with that domain name. Or a wildcard
*.mommy.web-wallet.com
Hello, thanks a lot for this answer.
I tried with this:
sudo ./certbot-auto certonly --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns -d web-wallet.com -d www.*.web-wallet.com -d *.web-wallet.com
But i get the following:
An unexpected error occurred:
The request message was malformed :: Error creating new order :: DNS name had a malformed wildcard label
There is no way to make it automatique so i dont have to update for every future subdomain?
*.*.web-wallet.com
give me an error as well because more than one whild card.
Thanks in advance :slight_smile:
doesn't exist and isn't defined.
Same.
You can't use one domain name with two * or the * not on the first place.
Ok so i have to update the certificate an add each subdomaine everytime i create one is that correct?
Yes. But is it really required to have the sub-subdomain www?
Main domain -> you should have a www.
But subdomains normally don't have an additional www version.
My own subdomain service uses *.server-daten.de (sample - the check-your-website.server-daten.de), but not www.check-your-website.server-daten.de.
There is no dns entry defined -> so no certificate is required.
So add the subdomains manual in your dns, not with a wildcard -> then www - subdomain doesn't exist.
Thanks for the infos, i could just put a redirect from www to non www for subdomain actually, i will go with this, thank you :slight_smile:
