Trying to install on my NAS which is some version of linux.
What kind of device are you running? And what does wget --version output?
I’m guessing a Zyxel NAS looking at the TLD of your domain. Which would probably make your wget not a wget at all, but a BusyBox function which not always has TLS(/SSL) support build in. It seems your BusyBox was compiled without TLS support.
My own Zyxel NAS does have curl. However, its /etc/ssl/certs/ directory is empty… Therefore, it will give an error complaining about not able to get a local certificate to verify the connection.
With the following command you can download certbot-auto:
If it also complains about not being able to verify the SSL certificate, you can add the -k option. However, your download is then insecure. If you do this, you should check the validity of certbot-auto:
In one indication of the limitations of this verification strategy, the correct value has changed since yesterday (!) due to the release of Certbot 1.2.0.
The correct value is now 0b2548809531fa447352718d54b6271deffdb7d3be24762b01c801ee8f22ffbc and will continue to change regularly in the future as a result of ongoing Certbot releases.
