Error with wget certbot-auto
My domain is: I want to get SSL activate for my webserver which have many domains names,
I ran this command: wget https://dl.eff.org/certbot-auto
–2019-01-11 08:00:51-- https://dl.eff.org/certbot-auto
Resolving dl.eff.org… 151.101.136.201, 2a04:4e42:20::201
Connecting to dl.eff.org|151.101.136.201|:443… connected.
OpenSSL: error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
Unable to establish SSL connection.
My web server is (include version): Apache 2.2.16
The operating system my web server runs on is (include version): Ubuntu 10.10
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): no, I use Putty
Hi @bvideosm
how old is your OpenSSL? Check it with
OpenSSL version
Ubuntu 10.10 is very old.
EOL in 2012 (almost 7 years ago)
source: Releases - Ubuntu Wiki
My OpenSSL version is 0.9.8o
So I should update my ubuntu version ?
Can you tell me if upgrading ubuntu is simple ?
Does it means that I will have to redo all the settings ?
Does my website will be down form some time ?
Thanks for your help !
A1. Probably yes - most likely.
A2. It should be but I'm not familiar with your specific setup so I can't be 100% certain.
A3. I would not know all the setting that you have made, so that is impossible for me to answer. In general, no - most settings are kept/upgraded.
A4. The system may have to reboot (maybe more than once) to get to a recent version. So, there will be some downtime/interruptions.
I would highly recommend doing a "snapshot" (if using a VM type system) or a full backup otherwise BEFORE MAKING ANY CHANGES.
You must update OpenSSL to support the newer protocols/ciphers.
Thanks for your answer !
To make a full backup, can you tell me if it’s ok if I do
tar czf /var/backups/_backup-20190111.tgz .
Does it will copy all the config and settings ? or do I need to copy something else ?
Thanks again ?
I understand you need help.
But the help that you seem to need now is outside the scope of this forum.
