Website timing out after I insalled SSL using Certbot
My domain is: curieux.in
I ran this command: I installed certificate according to certbot’s guide. (I am running nginx on ubutnu 18.04 machine)
It produced this output: My website times out now. While installing the certificate I did the force https option.
My web server is (include version): I am running nginx on an Ubuntu 18.04 machine.
My hosting provider, if applicable, is: digital ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
Check your server’s firewall settings. You currently do not have port 443 permitted.
ufw status
or if you are using DigitalOcean Cloud Firewall, check that.
Thank you so much!
I just allowed the port 443 through ufw and it works like a charm!
Many many thanks!
(Can be marked as resolved now.)
