Webroot for my site
produitma.com
certbot certonly
webroot for produitma.com
my app is deployed on heroku
I can login to a root shell on my machine (yes or no, or I don't know):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):1.17.0
how can I find my webroot
Hi @yurey, and welcome to the LE community forum :slight_smile:
Search through the web servers vhost config files.
Can you show a picture of that output?
Also, I'm having trouble resolving your domain names:
produitma.com
www.produitma.com
[is that spelled correctly?]
Also, it seems that you are using CloudFlare (at least for DNS).
If so, then you could easily use their certificate system.
I tried the cloudflare ssl but it doesn't work.
the domain is spelled right ..
With DNS they may all fail.
nslookup produitma.com doesn't return an IP.
how can i fix this error sir
Do you have access to modify/verify the DNS zone entries?
I fixed that .. the error appered to be from cloudflare
anyways .. I did try cloudflare ssl certificate but it didn't work .. and I wanna do it trough certbot
