Web based validation failed
My domain is: technoreso.com
I ran this command: certbot certonly -a webroot -w /var/www/html -d technoreso.com -d www.technoreso.com
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Requesting a certificate for technoreso.com and www.technoreso.com
Certificate is saved at: /etc/letsencrypt/live/technoreso.com/fullchain.pem
Key is saved at: /etc/letsencrypt/live/technoreso.com/privkey.pem
This certificate expires on 2024-03-27.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
root@host:~# sudo certbot renew
Processing /etc/letsencrypt/renewal/technoreso.com.conf
The following certificates are not due for renewal yet:
/etc/letsencrypt/live/technoreso.com/fullchain.pem expires on 2024-03-27 (skipped)
No renewals were attempted.
root@host:~# certbot certonly --force-renew -d technoreso.com
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Certificate is saved at: /etc/letsencrypt/live/technoreso.com-0001/fullchain.pem
Key is saved at: /etc/letsencrypt/live/technoreso.com-0001/privkey.pem
My web server is (include version): Linux 5.15.0-67-generic on x86_64
The operating system my web server runs on is (include version): Ubuntu Linux 22.04.3
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Webmin 2.105 |
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): N.A.
Please don't do this. What was your goal with the above command? For testing future renewals you should use certbot renew --dry-run, NOT --force-renewal.
Now you have a duplicate certificate, although without the www subdomain. Was that the goal?
The Certbot version is very much applicable.
Also: the thread title claims a failure, but in your post I don't see any failure mentioned?
can you please tell me how to check certbot version and virtualmin version
and my goal is to my website is showing insucure whenever i am opening www.technoreso.com
and when I am trying to Request for SSL Certificate it is showing like this
Renewing an existing certificate for technoreso.com and 4 more domains
Domain: admin.technoreso.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for admin.technoreso.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for admin.technoreso.com - check that a DNS record exists for this domain
Domain: webmail.technoreso.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for webmail.technoreso.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for webmail.technoreso.com - check that a DNS record exists for this domain
Domain: mail.technoreso.com
Detail: 103.180.163.174: Invalid response from http://mail.technoreso.com/.well-known/acme-challenge/4nC2LMZ-I6j6YQAeUlD_lP1NdFGGFxlVwLOpkbWvTXQ: 404
You are getting a certificate that includes both technoreso.com and the www subdomain. But, your Apache server is not configured to use it. Your apache is using a self-signed cert.
You need to change your VirtualHost that handles port 443 to use your new cert. Does VirtualMin do that or do you have to change Apache config manually?
