I running DS116 Synology with DSM 6.1.3-15152 Update 6
I use the free certificate from Let’s Engrypt “rvwing.synology.me”
My present situation is as follow
01 I Have a Domain registration by TransIp (NOT Active)
02 I have a Comodo Positive SSL Certificate "rvwing.eu"
03 I have a dynamic IP address that can change any time.
Can somebody help me how to convert my certificate to Let’s Encrypt included dynamic IP support?
When you create a help topic it asks you the following questions. We do need your domain name
Note: you must provide your domain name to get help.
Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
Having a dynamic IP address is okay. You don’t need to replace your certificates when your IP changes, whether you’re using Comodo or Let’s Encrypt.*
Do you want to get a Let’s Encrypt certificate for rvwing.eu? You can do that. The Comodo certificate doesn’t matter. You can have certificates from two CAs at the same time.
* Some CAs offer certificates for IP addresses. Let’s Encrypt doesn’t. I don’t know if Comodo does. But you probably don’t have one.
My Domain registration is registered by TransIP. They expect an FIX IP address and don’t support dynamic IP address. So any time my IP address change I have to do that manual fill in the new IP address. I looking for a solution of this my dynamic IP address…
Synology and Let’s encrypt certificate base on DDNS that is running in my NAS. For my this is OK. This cover my dynamic IP addressing problem. Only I cannot run my “rvwing,eu” from comodo certificate. I like use “rvwing.eu”
Set my DNS (TransIP) to “rvwing.eu” I checked and is OK.
Request Synology support for to get the Plugin that allows for use of the HTTP Challenge.
Have to wait for an answer…
Synology supports Let’s Encrypt without the need for any plugin. The process to request a certificate via the Synology web interface is described here:
Please note that your custom domain must be pointed at your Synology server to obtain certificates with the Synology client. If the A record for your domain is pointed at a different server, you should install a client such as certbot on that server to obtain a certificate for it.
It will try to resolve your domain name to an IP (static or dynamic depending on your provider) and it will try to talk to that IP to get the validation
For Let’s Encrypt’s purposes, the site’s A and AAAA records only matter for a few seconds once every 2-3 months, while the certificate is being renewed. (With DNS-01 validation, which uses a TXT record, they never matter.)
While you probably need the DNS records to be correct 24/7 so people can visit your website, for Let’s Encrypt’s purposes, it doesn’t matter 99.9999% of the time.
What I learn, the best option is to use my external access name.
Let’s Encrypt create the certificate name "rvwing.synology.me"
This solve my problem included dynamic IP address.
Conclusion.
Can use only my domain “rvwing.eu” with an Static IP address.
Thx for your assistance, greet…
Best regards, Rob73 The Netherlands
You can go into TransIP’s control panel to your domain’s DNS settings and add a CNAME record pointing a subdomain, e.g. synology.rvwing.eu, to rvwing.synology.me if you want.
(You can’t use the naked rvwing.eu this way with TransIP, because it does not support ALIAS records/CNAME flattening like some other DNS providers do.)
I’m not sure why a wildcard (*) record would affect your email, as it should affect everything but the apex domain.
But this is why I suggested using a subdomain like synology.rvwing.eu, because I knew for certain that this wouldn’t break any services you have with TransIP.
I test all, it is working at the moment that I made the changes, BUT after 24 hours the wildcard and subdomain setting are rejected. So I am start from the scratch. I will stop this in this forum. To all users thanks for your time and understanding etc… was good to learn difference DNS setup on the END it is NOT working, Be happy and continue with next topic
If you’re still having trouble getting your DNS in shape, I would suggest contacting TransIP’s technical support. They would be able to easily restore their default records if you’re still having trouble with their services like e-mail and they would also be able to identify why you are having trouble setting up a subdomain CNAME record for synology with their infrastructure.
TransIP answer, Standard the record should start with a type A record with a static IP Address. In this case it is NOT present. Instead I use type CNAME that ref to my “External Access” as a subdomain. It is a simple solution, NOT professional example E-Mail server can’t run on it. For me it is an compromise and working fine…
