Using Letsencrypt with a java spring-boot application
I’m developing my site (mi16s.ru) and trying to establish secure connection to it.
My hosting provider provide me with Debian 9 stretch server with SSH access.
I use nginx as a web server, and tomcat8 as application server.
For secure access I installed certbot package.
For static HTML pages everything works fine. When I try to open the site by typing mi16s.ru as URL, the site is opened over secure connection as https://mi16s.ru
I also developed a java spring-boot application, built it as phog.war file and installed the file into /var/lib/tomcat8/webapps directory
When I try to open the application by typing mi16s.ru:8080/phog it is opend over unsecure connection as http://mi16s.ru:8080/phog/
Now I want to configure my site so that not only staic pages (e.g. /var/www/html/index.html) are opened over secure connection, but dynamic spring-boot applications (e.g. /var/lib/tomcat8/webapps/phog.war) will be opened over secure connection either.
I create file /etc/letsencrypt/live/mi16s.ru/bundle.pfx
and add the following lines into file /etc/nginx/sites-enabled/default:
listen 80;
listen [::]:80;
server_name mi16s.ru;
        proxy_pass http://127.0.0.1:8080;
        proxy_set_header Host      $host;
But again the application is opened only over unsecure connection.
If I try to open it by typing https://mi16s.ru:8080/phog/ I get an error message: “An error occurred during a connection to mi16s.ru:8080. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG”
If I try to open it by typing https://mi16s.ru/phog/ I get an error message: “404 Not Found”
I noticed that file /etc/letsencrypt/live/mi16s.ru/bundle.pfx is owned by root and has mode: 600, trying to change its mode to 644 does nothing.
I noticed also, that when I run the command: “systemctl restart nginx” I get error messages in file /var/log/nginx/error.log:
conflicting server name “mi16s.ru” on 0.0.0.0:80, ignored
conflicting server name “mi16s.ru” on [::]:80, ignored
I don’t understand what these messages mean, but think there is something wrong in my file /etc/nginx/sites-enabled/default, so here it is all:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
	listen 80 default_server;
	# SSL configuration
	root /var/www/html;
	server_name _;
		try_files $uri $uri/ =404;
	#location ~ \.php$ {
	#	include snippets/fastcgi-php.conf;
	#	# With php-fpm (or other unix sockets):
	#	fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
	#	# With php-cgi (or other tcp sockets):
	#	fastcgi_pass 127.0.0.1:9000;
	# concurs with nginx's one
	#location ~ /\.ht {
	#	deny all;
#server {
#	listen 80;
#	listen [::]:80;
#	server_name example.com;
#	root /var/www/example.com;
#	index index.html;
#	location / {
#		try_files $uri $uri/ =404;
	# SSL configuration
	root /var/www/html;
    server_name mi16s.ru; # managed by Certbot
	#location ~ /\.ht {
	#	deny all;
    ssl_certificate /etc/letsencrypt/live/mi16s.ru/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/mi16s.ru/privkey.pem; # managed by Certbot
    if ($host = mi16s.ru) {
    } # managed by Certbot
	listen 80 ;
	listen [::]:80 ;
        listen 80;
        listen [::]:80;
Can anybody help me to configure secure access to my application.
Thank you, Mikhail.
Hi @mr16
I moved your question to a new topic, makes it easier.
Your error
says: Your port 8080 sends http content. Checked your domain / port with my tool ( https://check-your-website.server-daten.de/?q=mi16s.ru%3A8080 ), there you see the error:
78.24.221.106 200 0.134 H
http://www.mi16s.ru:8080/
78.24.221.106 200 0.117 H
78.24.221.106 -4 0.224 W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send. The handshake failed due to an unexpected packet format.
https://www.mi16s.ru:8080/
78.24.221.106 -4 0.217 W
That's a correct http port.
I'm not so firm with Tomcat. But there are additional steps required that you can use a certificate with tomcat (saving the certificate in a format so you can import it in a java key store).
I don't see the port in your nginx config. So it's only a thing of your tomcat. But you can reuse the same certificate.
PS:
You have two listen 80 / listen [::]:80 directives with the same server name
So one is ignored. Perhaps remove (comment) the first.
Hi JuergenAuer,
Thank you for your answer.
At first I wanted to establish web site with both static (HTML pages) and dynamic (spring-boot application) content. But then I saw the task was too complicated (for me).
So I decided that my server would support only my spring-boot application, no static HTML pages. I rebuild my application as JAR file and configure the site as
gamujtaba explains in his “How can i install letsencrypt ssl on java app” messages.
Now all works fine.
Mikhail
PS
Perhaps later when I gain more experience I will add static HTML pages support to my site too.
