Does anyone have any experience with using Let's Encrypt/Certbot on an embedded Tomcat server with Spring Boot, which is being run in a Docker container? I can't seem to get this working.
Hi @furdturg and welcome to the LE community forum
I'm not sure if Spring Boot requires anything non-standard or not.
I'm pretty sure Docker containers can be used like any other VM type solution.
And I do know that Apache Tomcat is no ordinary Apache and should be dealt with by following their recommended installation procedures OR simply place it behind a regular reverse proxy (for faster results).
So... if you can NAT the ports (80/443) to your host and extend (expose) them to the Docker instance, you should be able to obtain a cert for your Tomcat via certbot with HTTP-01 authentication.
I don't have any guide for such a feat but, if you break it down, it really isn't that complicated.
[the hardest part is dealing with Apache Tomcat]
