SSL for Tomcat8 (Resolved)
Hey guys,
I am using letsencrypt for the first time. We have a subdomain for our site. The thing is i have retrieved the certificate files fullchain.pem, privykey.pem, cert.pem, chain.pem and i am running a Tomcat8 Webserver. I have googled a lot for the configuration of server.xml and havent found any solution. The webserver is running on port 8080 i am running ubuntu 16.04 on digitalocean. Can someone please share the server.xml file on how to configure it ? Any help is appreciated.
Thank you.
Hi @syed1,
Have you looked at some of the previous threads on this topic here?
https://community.letsencrypt.org/search?q=tomcat%20jks
Hi @schoen
Yup, tried all of it. The problem is most of them suggest to convert to JKS or pkcs12 format. but once i do that the certificate is invalid (it says not secure). i have pem files, tried all the treads what the community has suggested it isnt working. I need help with the configuration of server.xml file.
I did try reverse proxy using apache2 all in vain :frowning:
Hi @schoen
It is resolved.
  1. mkdir -p /etc/tomcat8/keystore/
  2. openssl pkcs12 -export -in /etc/letsencrypt/live/yourdomain.com/fullchain.pem -inkey
/etc/letsencrypt/live/yourdomain.com/privkey.pem -out /etc/tomcat8/keystore/students.kodebay.com.p12
-password pass:yourpassword
  1. keytool -importkeystore -srckeystore /etc/tomcat8/keystore/yourdomain.com.p12 -srcstoretype pkcs12 -
srcstorepass yourpassword -destkeystore /etc/tomcat8/keystore/yourdomain.com.keystore -
deststoretype jks -deststorepass yourpassword
Thanks to @sahsanu His reply on a tread helped me. The above procedure works!
Thanks @schoen
