My domain is: wiki.heinrich-stefan.eu
I ran this command: /usr/etc/certbot-auto renew --dry-run
It produced this output: Attempting to renew cert (wiki.heinrich-stefan.eu) from /etc/letsencrypt/renewal/wiki.heinrich-stefan.eu.conf produced an unexpected error: Failed authorization procedure. wiki.heinrich-stefan.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://wiki.heinrich-stefan.eu/.well-known/acme-challenge/jTCXKkSZoOsIkzQ2W-lmRO1h-PB3rRSC7c4wg4TB7AU: “\n\n403 Forbidden\n\n
Forbidden
\n<p”. Skipping.All renewal attempts failed. The following certs could not be renewed:
/etc/letsencrypt/live/heinrich-stefan.eu/fullchain.pem (failure)
/etc/letsencrypt/live/wiki.heinrich-stefan.eu/fullchain.pem (failure)
The operating system my web server runs on is (include version): Ubuntu
I can login to a root shell on my machine (yes or no, or I don’t know): >es
or certbot-auto --version
if you’re using Certbot): 0.30.2
Hello
The Error mentioned is only occuring on subdomain vhost. With direct Domain vhost it is working. The Vhost config of this hosts is copied and only path is changed. When i manually place a file in .well-known/acme-challenge this file is accessible given that the file Rights are set correctly read Access for all.
Thanks in advance
