Using Encrypt for non standard ports (revived)
I’ve seen the posts on how to setup Let’s Encrypt for non-standard ports using the TXT record method but it still fails. I can’t understand how this TXT record instructs the verification process to use the non-standard port.
root@eve-ng:/usr/local/sbin# certbot-auto -d eve-ng.networkdavid.net --manual --preferred-challenges dns certonly
dns-01 challenge for eve-ng.networkdavid.net
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
Please deploy a DNS TXT record under the name
_acme-challenge.eve-ng.networkdavid.net with the following value:
yj6t4Kj-rD0rwrjlMDN5Cb2Er2f9Y9pU0blQd4VU95I
Once this is deployed,
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. eve-ng.networkdavid.net (dns-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.eve-ng.networkdavid.net
    Domain: eve-ng.networkdavid.net
    Type: connection
    Detail: DNS problem: NXDOMAIN looking up TXT for
Description: Ubuntu 16.04.2 LTS
Hi @davparker,
You might have misunderstanding the context. Doing the verification using the TXT record is an alternative to having the CA connect to your server; it doesn't use any ports at all because there is no connection made to your server.
Did you actually create a record for _acme-challenge.eve-ng.networkdavid.txt as requested? I currently don't see it when I try to look it up.
