Using Certbot container on Synlogy NAS
My domain is: intranet.domain.com
sudo docker run --rm
-v /docker/nginx/certs:/etc/letsencrypt
-v /docker/nginx/lib:/var/lib/letsencrypt
-v /docker/nginx/html:/usr/share/nginx/html
-v /docker/nginx/certbot-logs:/var/log/letsencrypt
certbot/certbot certonly --webroot -w /volume1/docker/nginx/html
-d intranet.piereslikkers.nl
--email email@email.nl --agree-tos --no-eff-email
--log /var/log/letsencrypt/certbot.log
docker: Error response from daemon: Bind mount failed: '/docker/nginx/certbot-logs' does not exists.
nginx docker the latested
Synlogic dsm 7.2.2-72806 update 2 whit container manager installed
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I am using the latested certbot docker
I am no docker expert but doesn't that mean your host does not have the directory?
