nginx.conf.txt (916 Bytes) Dockerfile.txt (693 Bytes) Install-Certbot.txt (409 Bytes)
Hello @mrunal-modi, welcome to the Let's Encrypt community.
$ nmap -Pn -p80,443 fiscaltimeline.com
Starting Nmap 7.80 ( https://nmap.org ) at 2023-12-15 03:25 UTC
Nmap scan report for fiscaltimeline.com (3.25.246.4)
Host is up.
rDNS record for 3.25.246.4: ec2-3-25-246-4.ap-southeast-2.compute.amazonaws.com
PORT STATE SERVICE
80/tcp filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.29 seconds
ANotWorking
ERROR
fiscaltimeline.com has an A (IPv4) record (3.25.246.4) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with fiscaltimeline.com/3.25.246.4: Get "http://fiscaltimeline.com/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://fiscaltimeline.com/.well-known/acme-challenge/letsdebug-test (using initial IP 3.25.246.4)
@0ms: Dialing 3.25.246.4
@10001ms: Experienced error: context deadline exceeded
IssueFromLetsEncrypt
ERROR
A test authorization for fiscaltimeline.com to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
3.25.246.4: Fetching http://fiscaltimeline.com/.well-known/acme-challenge/9tKWj5i_7LZHm5mV2hQWbbdQIOXZmdDip-dPPUKv0SA: Timeout during connect (likely firewall problem)
I tried too many time and now have been supended for 24 hours. Shall bring it online on 80 again tomorrow. Meanwhile, any issues with my setup to test? Makefile , Dockerfile ?
