Using Certbot and DNS01
I wish to use Certbot with my nginx server and I want to use DNS-01 for validation. When I run certbot at the moment it is trying to use HTTP which I do not want to use. I then want it to auto-renew the certificates.
I have had a look at the documentation, but my Linux-fu isn’t very good :frowning: Could someone kindly point me in the right direction please?
For DNS-01 to work in an automated fashion, you will need to have an ACME client that supports a DNS API plugin that works with your DNS provider.
Step #1: See if your DNS provider has an API to update DNS zone entries.
If NO (to #1), stop and you will have to do it manually or introduce an alternate DNS provider/system to handle the DNS authentication challenges.
If YES (to #1), Proceed.
Step #2. Finding the right ACME client
This will require matching the ACME client to your specific O/S (and version) and the DNS API plugin support. You can start here for that:
And, of course, return here with any further questions or problems that you may encounter.
[ hopefully few - and simple ones :slight_smile: ]
Thanks rg. I do not believe that our DNS provider has an API.
