Certbot automation with 3rd Party DNS provider?
My web server is (include version): apache
The operating system my web server runs on is (include version): Debian 12
My hosting provider, if applicable, is: autodns.com
Hi Team,
is it possible to integrate a 3rd party API (not supported directly from certbot) with certbot?
the goal is to automate the renewal operations for wildcard Zertificates.
well appreciated
Hi @raven4d, and welcome to the LE community forum :slight_smile:
There are hooks that can be used.
See:
User Guide — Certbot 3.1.0.dev0 documentation
You might also consider looking at other ACME clients - maybe one of them has an API for you DSP.
Just adding to rg305 comment ... both acme.sh and lego have support for a wide variety of DNS providers as standard, as two examples
many thanks fĂĽr the quick reply!
this is exactly what i was looking for
have a nice day
cheers!
And if you wish to keep using Certbot with any DNS API which is covered by lego, you could use certbot-dns-multi which uses lego under the hood.
If you are skilled enough to develop your own extensions for the DNS API you might consider using Apache mod_md and its extensions.
That is an ACME Client built into Apache avoiding the need to install something else
Using mod_md would be easier to manage a collection of domain names without needing a wildcard too. Even using the TLS-ALPN challenge (port 443). But it does support DNS Challenges although I have no personal experience with that part of it.
https://httpd.apache.org/docs/2.4/mod/mod_md.html
