Then restart nginx
and reshow:
netstat -pant | grep -i nginx
I am unable to restart nginx service, I am getting below error,
ananth@ananth:~$ sudo systemctl restart nginx.service
Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
ananth@ananth:~$ sudo systemctl status nginx.service
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2018-12-20 11:04:01 IST; 29s ago
Process: 30927 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry QUIT/5 --pidfile /run/nginx.pid (code=exited, status=0/SUCCESS)
Process: 30930 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Main PID: 17413 (code=exited, status=0/SUCCESS)
Dec 20 11:04:01 ananth systemd[1]: Starting A high performance web server and a reverse proxy server...
Dec 20 11:04:01 ananth nginx[30930]: nginx: [emerg] unknown directive "lHost" in /etc/nginx/sites-enabled/https.conf:3
Dec 20 11:04:01 ananth nginx[30930]: nginx: configuration file /etc/nginx/nginx.conf test failed
Dec 20 11:04:01 ananth systemd[1]: nginx.service: Control process exited, code=exited status=1
Dec 20 11:04:01 ananth systemd[1]: Failed to start A high performance web server and a reverse proxy server.
Dec 20 11:04:01 ananth systemd[1]: nginx.service: Unit entered failed state.
Dec 20 11:04:01 ananth systemd[1]: nginx.service: Failed with result 'exit-code'.
If you added the vhost config in the /etc/apache2/sites-enabled/000-default.conf
file, just delete this file:
I have deleted https.conf files in /etc/apache and /etc/nginx. I am getting below output,
ananth@ananth:~$ sudo netstat -pant | grep -i nginx
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 32485/nginx -g daem
tcp6 0 0 :::80 :::* LISTEN 32485/nginx -g daem
Please show:
nginx -t
Please view it,
ananth@ananth:~$ sudo nginx -t
From inside the 4443 block, remove:
and (near the bottom) one of the
Although the nginx -t
(test) passed…
It seems it may not like server {block} (inside a vhost) inside another server{block}.
Hopefully that will fix get the 4443 problem and get it running.
Restart nginx and show:
You want me to remove “server {” aand “}”, not code inside in that.
Correct, only delete the start and end for server block - leave all the code inside.
I worked hard to create it just for you
yes… You are working hard for me to solve this issue. I have other projects are running parallel but I am giving important to this. I will update you the result.
I have modified code in "/etc/apache2/sites-enabled/000-default.conf ",
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =veplopenhab.ga
</VirtualHost>
<VirtualHost *:4443>
#server {
listen 4443 ssl;
server_name veplopenhab.ga;
ssl_certificate /etc/letsencrypt/live/veplopenhab.ga-0001/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/veplopenhab.ga-0001/privkey.pem;
# error_log /location/to/error.log.file
proxy_pass https://localhost:8443/;
proxy_set_header Host $http_host;
satisfy any;
allow 10.0.0.0/8; # ONLY Internal network has access
allow 127.0.0.1;
deny all;
</VirtualHost>
Still, issue is not resolved.,
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2368/nginx -g daemo
tcp6 0 0 :::80 :::* LISTEN 2368/nginx -g daemo
For testing, try changing:
to:
listen 4443;
I have removed “ssl” from the code,
listen 4443;
still, getting the same issue.
I am not understanding why it fails.
I will try that vhost config in lab and get back to you on what I find.
We have been working with the wrong file
That is an APACHE file.
We need to modify an NGINX file.
EPIC FAIL
Oh… That’s why when I modified a file, I have mentioned its whole path for visibility. I thought you have noticed. I need to modify some file in nginx folder like “/etc/nginx/sites-enabled/000-default.conf”.
Am I correct?
YES! NGINX
Please show:
ls -l /etc/nginx/sites-enabled/
I can revert the changes which I made in "/etc/ apache2 /sites-enabled/000-default.conf "
ananth@ananth:~$ sudo ls -l /etc/nginx/sites-enabled/
[sudo] password for ananth:
total 0
lrwxrwxrwx 1 root root 34 Dec 7 11:45 default -> /etc/nginx/sites-available/default
Please show file:
and also file:
or output of:
grep -Eri 'include|listen|virtual|server_|ssl_cert' /etc/nginx/
