I am getting this outptut
Please show both:
more /etc/nginx/sites-enabled/https.conf
more /etc/nginx/sites-available/https.conf
and
ls -l /etc/nginx/sites-enabled/
OR we can just add directly to the /etc/nginx/nginx.conf file.
Please delete both files:
rm /etc/nginx/sites-enabled/https.conf
rm /etc/nginx/sites-available/https.conf
and create one at:
with:
https.txt (669 Bytes)
Hi @_DJ
this is normal. Because ( https://check-your-website.server-daten.de/?q=veplopenhab.ga ):
| Host | T | IP-Address | is auth. | ∑ Queries | ∑ Timeout |
| veplopenhab.ga | A | 10.1.68.206 | yes | 1 | 0 |
| www.veplopenhab.ga | Name Error | yes | 1 | 0 |
With the result Grade Y:
|Y|veplopenhab.ga||---|---||||||10.1.68.206|||warning: Private ip address found: 10.0.0.0 to 10.255.255.255: Class A - one private net with 16.777.216 adresses|
You use a private ip address. That works only in a local environment.
yes… It is show my machine IP like 10.xx.xx.xx
Please show (again):
netstat -pant | grep -i nginx
We need to get nginx on port 4443.
Ok…We need to use 4443 port to nginx instead of 80.
Please modify the file:
/etc/apache2/sites-enabled/000-default.conf
and add this at the end of it:
So it will have 80 and 4443.
It need to change like this,
<VirtualHost *:80>
as
<VirtualHost *:4443>
No, the one file can have both:
<VirtualHost *:80>
…text
</VirtualHost>
…text
</VirtualHost>
I have modified like this ,
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =veplopenhab.ga
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
This is not a good modification.
Now that 4443 vhost config block is missing many things.
It will not work properly.
At best, it will only do http on port 4443 (and not proxy to 8443).
Make it look like this:
<VirtualHost *:80>
# modules, e.g.
RewriteEngine on
</VirtualHost>
listen 4443 ssl;
server_name veplopenhab.ga;
ssl_certificate /etc/letsencrypt/live/veplopenhab.ga-0001/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/veplopenhab.ga-0001/privkey.pem;
# error_log /location/to/error.log.file
proxy_pass https://localhost:8443/;
proxy_set_header Host $http_host;
satisfy any;
allow 10.0.0.0/8; # ONLY Internal network has access
allow 127.0.0.1;
deny all;
</VirtualHost>
sorry, I missed to add your previous changes which you given for proxy. I will try you new changes.
