Here is my first time at trying to do SSL since we forgot to renew the previous certificate in time (not a Let's encrypt certificate). And because the config from the previous team was messed up, I decided to uninstall completely the Apache and Nginx servers and strop from scratch with a new Nginx instance.
I've never done SSL, never used certbot and even my ubuntu knowledge is thin (don't laugh at the fact I am normally a dev who use Microsoft tech).
Now, as for the questions asked, here are the answers.
My domain is: reseautage.com
I ran this command: sudo certbot --nginx -d reseautage.com -d www.reseautage.com
It produced this output: See below for the full log
My web server is (include version): nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: DigitalOcean (the app is inside a droplet, if it is important to know)
Domain registration was made from another enterprise (Funio) and was working perfectly before.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Here is the content of the log after running the previous instruction.
2020-10-18 20:14:16,670:DEBUG:certbot.main:certbot version: 0.31.0
2020-10-18 20:14:16,671:DEBUG:certbot.main:Arguments: ['--nginx', '-d', 'reseautage.com', '-d', 'www.reseautage.com']
2020-10-18 20:14:16,672:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-10-18 20:14:16,679:DEBUG:certbot.log:Root logging level set at 20
2020-10-18 20:14:16,679:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-10-18 20:14:16,681:DEBUG:certbot.plugins.selection:Requested authenticator nginx and installer nginx
2020-10-18 20:14:16,779:DEBUG:certbot.plugins.selection:Single candidate plugin: * nginx
Description: Nginx Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: nginx = certbot_nginx.configurator:NginxConfigurator
Initialized: <certbot_nginx.configurator.NginxConfigurator object at 0x7f196f9ada90>
Prep: True
2020-10-18 20:14:16,781:DEBUG:certbot.plugins.selection:Selected authenticator <certbot_nginx.configurator.NginxConfigurator object at 0x7f196f9ada90> and installer <certbot_nginx.configurator.NginxConfigurator object at 0x7f196f9ada90>
2020-10-18 20:14:16,781:INFO:certbot.plugins.selection:Plugins selected: Authenticator nginx, Installer nginx
2020-10-18 20:14:16,785:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(terms_of_service=None, body=Registration(only_return_existing=None, external_account_binding=None, terms_of_service_agreed=None, agreement=None, contact=(), key=None, status=None), new_authzr_uri=None, uri='https://acme-v02.api.letsencrypt.org/acme/acct/69485234'), 63ff8271ab82b259b7eb73481bdf1a35, Meta(creation_dt=datetime.datetime(2019, 10, 15, 18, 16, 44, tzinfo=), creation_host='reseautage'))>
2020-10-18 20:14:16,787:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2020-10-18 20:14:16,789:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org
2020-10-18 20:14:16,989:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 658
2020-10-18 20:14:16,990:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 18 Oct 2020 20:14:16 GMT
Content-Length: 658
X-Frame-Options: DENY
"5iBn0_UTU08": "Adding random entries to the directory",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
2020-10-18 20:14:16,991:INFO:certbot.main:Obtaining a new certificate
2020-10-18 20:14:17,023:DEBUG:certbot.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0012_key-certbot.pem
2020-10-18 20:14:17,025:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0012_csr-certbot.pem
2020-10-18 20:14:17,025:DEBUG:acme.client:Requesting fresh nonce
2020-10-18 20:14:17,025:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2020-10-18 20:14:17,075:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2020-10-18 20:14:17,076:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 18 Oct 2020 20:14:17 GMT
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: 0004cfrLn7p4U0Ot_kt8Y4pt8YLvcBnbOwSF6RWwvFInKNI
2020-10-18 20:14:17,077:DEBUG:acme.client:Storing nonce: 0004cfrLn7p4U0Ot_kt8Y4pt8YLvcBnbOwSF6RWwvFInKNI
2020-10-18 20:14:17,077:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "value": "reseautage.com",\n "type": "dns"\n },\n {\n "value": "www.reseautage.com",\n "type": "dns"\n }\n ]\n}'
2020-10-18 20:14:17,081:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInZhbHVlIjogInJlc2VhdXRhZ2UuY29tIiwKICAgICAgInR5cGUiOiAiZG5zIgogICAgfSwKICAgIHsKICAgICAgInZhbHVlIjogInd3dy5yZXNlYXV0YWdlLmNvbSIsCiAgICAgICJ0eXBlIjogImRucyIKICAgIH0KICBdCn0",
"signature": "nb7zbwSFkY6dqA6f-k9WtB2SzvE3K3J3a4ReEJU2b6ZUrSkKYvQwo4pZ5S21KKl6p0L9FiZ5tUe4H8Xj7RkfKuuYsq47GL6P1_ej6mfgCe37AAUQEs6jCLGBe7sHd-NB6pfBqtjVclM9fhlTpk8B4MhLUszrLiTQzP7Rzwi9pbpTFjm_ZaBGo-ns8oYvcPJ9Y_LbHRoR4P-E_DjzFhQNSciRfmYLTu-vUbMncLnLKQK4XIlKxjhgMc-qRycIfIfGZ1C_-pAv3VoB8NYlbOm-qA2QIRTJHYAjxp0JURZpS9n8OddyLgL_b5UrF3UGu95wb-VcLBxz4Vsg-bGxL3sZPA",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwNGNmckxuN3A0VTBPdF9rdDhZNHB0OFlMdmNCbmJPd1NGNlJXd3ZGSW5LTkkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC82OTQ4NTIzNCJ9"
2020-10-18 20:14:17,170:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 483
2020-10-18 20:14:17,170:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 483
Boulder-Requester: 69485234
Location: https://acme-v02.api.letsencrypt.org/acme/order/69485234/5755233454
Replay-Nonce: 0003ng7GBD7jCQjtpQ1CkVu2djH08MOAztnFJsVZi1WOHoQ
"status": "pending",
"expires": "2020-10-25T20:14:17.128392479Z",
"identifiers": [
"type": "dns",
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928864",
"https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928866"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/69485234/5755233454"
2020-10-18 20:14:17,171:DEBUG:acme.client:Storing nonce: 0003ng7GBD7jCQjtpQ1CkVu2djH08MOAztnFJsVZi1WOHoQ
2020-10-18 20:14:17,171:DEBUG:acme.client:JWS payload:
b''
2020-10-18 20:14:17,172:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928864:
"payload": "",
"signature": "QGCHY8Q-FCYs8lppO5Y3C_lEWYTwB-YC41CKj8u9NB6IBgMSJ0EH4zXgRhWSxt6a_XBs-cDyRvReQKQu2ui1LAXQhP2k6C2SrGihqOvh6WEawTKEcPNoIT3SBSxzSMcqjKVIGCIS_-mKHPKt3RM8-iVZWvrHgr7O0lWtkBdkZWTPIV8noVdlmesOQ4QSdEjsEzxWheCVpSJv0-QyVBwNk-wDdHVOirQKNvgkigAxxAfKt2thQqxm4PeeGFEnsMh9cQMq9GUo8wp-Mj_N0dZTqkm2czvDi9h4rMdXCEUjbesVnY4wREzRPQ3LVP0UvfbJQnbxTH6olyNL2B9S6HLrHQ",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwM25nN0dCRDdqQ1FqdHBRMUNrVnUyZGpIMDhNT0F6dG5GSnNWWmkxV09Ib1EiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzc5ODM5Mjg4NjQiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNjk0ODUyMzQifQ"
2020-10-18 20:14:17,226:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/7983928864 HTTP/1.1" 200 792
2020-10-18 20:14:17,227:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 792
Replay-Nonce: 0004UapEZo9hSvDAv67fX2lq5j0hUznmbua6bo1ORGVO5-w
"identifier": {
"type": "dns",
"expires": "2020-10-25T20:14:17Z",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928864/YQWvqA",
"token": "esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928864/hEf3Cw",
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928864/JL0enw",
2020-10-18 20:14:17,227:DEBUG:acme.client:Storing nonce: 0004UapEZo9hSvDAv67fX2lq5j0hUznmbua6bo1ORGVO5-w
2020-10-18 20:14:17,227:DEBUG:acme.client:JWS payload:
b''
2020-10-18 20:14:17,229:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928866:
"payload": "",
"signature": "qWYoY7x5oBN_eZaTkfzEdq85HXw02nPsaY-cL0Zv30W5mxd07fhQ34H7bjPJBOlJ3XwBdcTQL8VbnN2VLqBm7qe_Qaeb7GGY1ahA7MW8Hh8ULlkrCwF7dx3cGQV0FAiv3zuRMb_uXnQFa_rDfOP26Y6YaaahckEUgJgtH2ILjzrg42pKySAirHlQLOh2stjAcgULlQTJAVOGlyYWfmTbF8eAEradc65Ada5AN2DWoYA8dD8UPB0pgt1lPxiWkrRfWWNu0a9nF99Fo3xnoD9EgY5EoZ7bcjNXhWuPoBKBSNGIUqVtGuh59rsUxqxBiNupzxr-Ri-c7LqunA6BOzqY4g",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwNFVhcEVabzloU3ZEQXY2N2ZYMmxxNWowaFV6bm1idWE2Ym8xT1JHVk81LXciLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzc5ODM5Mjg4NjYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNjk0ODUyMzQifQ"
2020-10-18 20:14:17,283:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/7983928866 HTTP/1.1" 200 796
2020-10-18 20:14:17,283:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 796
Replay-Nonce: 0001VgbWJ_stRzDcINYQgIT8a6MVTealfLofwvvpQwqw-mc
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928866/y4jlqA",
"token": "3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928866/AbMNUA",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928866/H-0P_w",
2020-10-18 20:14:17,284:DEBUG:acme.client:Storing nonce: 0001VgbWJ_stRzDcINYQgIT8a6MVTealfLofwvvpQwqw-mc
2020-10-18 20:14:17,284:INFO:certbot.auth_handler:Performing the following challenges:
2020-10-18 20:14:17,285:INFO:certbot.auth_handler:http-01 challenge for reseautage.com
2020-10-18 20:14:17,286:INFO:certbot.auth_handler:http-01 challenge for www.reseautage.com
2020-10-18 20:14:17,306:DEBUG:certbot_nginx.http_01:Generated server block:
2020-10-18 20:14:17,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/mime.types
2020-10-18 20:14:17,306:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/reseautage.com
2020-10-18 20:14:17,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/sites-enabled/default
2020-10-18 20:14:17,307:DEBUG:certbot.reverter:Creating backup of /etc/nginx/nginx.conf
2020-10-18 20:14:17,307:DEBUG:certbot_nginx.parser:Writing nginx conf tree to /etc/nginx/sites-enabled/reseautage.com:
server {rewrite ^(/.well-known/acme-challenge/.*) $1 break; # managed by Certbot
listen 80;
listen [::]:80;
root /var/www/reseautage.com/html;
server_name reseautage.com www.reseautage.com;
try_files $uri $uri/ =404;
location = /.well-known/acme-challenge/esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc{default_type text/plain;return 200 esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc.ulZ63PjhLaUVfpFl6pkNXPpCJXffN4z2n7NtrZ2IXN0;} # managed by Certbot
location = /.well-known/acme-challenge/3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs{default_type text/plain;return 200 3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs.ulZ63PjhLaUVfpFl6pkNXPpCJXffN4z2n7NtrZ2IXN0;} # managed by Certbot
2020-10-18 20:14:17,308:DEBUG:certbot_nginx.parser:Writing nginx conf tree to /etc/nginx/nginx.conf:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
include /etc/letsencrypt/le_http_01_cert_challenge.conf;
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
server_names_hash_bucket_size 128;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# See sample authentication script at:
# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# auth_http localhost/auth.php;
# pop3_capabilities "TOP" "USER";
# imap_capabilities "IMAP4rev1" "UIDPLUS";
listen localhost:110;
protocol pop3;
proxy on;
listen localhost:143;
protocol imap;
proxy on;
2020-10-18 20:14:18,324:INFO:certbot.auth_handler:Waiting for verification...
2020-10-18 20:14:18,325:DEBUG:acme.client:JWS payload:
b'{\n "keyAuthorization": "esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc.ulZ63PjhLaUVfpFl6pkNXPpCJXffN4z2n7NtrZ2IXN0",\n "type": "http-01",\n "resource": "challenge"\n}'
2020-10-18 20:14:18,327:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928864/YQWvqA:
"payload": "ewogICJrZXlBdXRob3JpemF0aW9uIjogImVzcmNZb2d4U3BTQ28wZDhFQ19ySXFCZVB5VFh1eUtyVWtPbWVxOEtYVWMudWxaNjNQamhMYVVWZnBGbDZwa05YUHBDSlhmZk40ejJuN050cloySVhOMCIsCiAgInR5cGUiOiAiaHR0cC0wMSIsCiAgInJlc291cmNlIjogImNoYWxsZW5nZSIKfQ",
"signature": "CO5Sd7_rghV8twzbKpGqLEkXBgIGEe9nkpKQ6d5Jq_c31c3xncAWXXR3gjKMGqNWxEAMrC2QcDWW2I_fwiKCTajrLoIkRoaosUmW7IJ6tLih80e_hL-_vh-wL70a3usQA6l_M_mvPzSSGO0DaIMWE2XWfqHh9RVFA7jCVf0HVOYCeIXKkqhloPeYwarEK7Ddk5Y0xLIOnNIVnSiPFZToGsUeoq3SGo6POgdLpChSvnpdQziYt-lwoD8I-y5U8pIOVDRDRw26wk95Ey71FqebEILNpbqfegOF4qjZnvlAIrSt2Qlmu_Bx1S83DDgN3zNKC24_3DfmP2WI-AjK72JdNw",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwMVZnYldKX3N0UnpEY0lOWVFnSVQ4YTZNVlRlYWxmTG9md3Z2cFF3cXctbWMiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsLXYzLzc5ODM5Mjg4NjQvWVFXdnFBIiwgImtpZCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0LzY5NDg1MjM0In0"
2020-10-18 20:14:18,393:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/7983928864/YQWvqA HTTP/1.1" 200 185
2020-10-18 20:14:18,394:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 18 Oct 2020 20:14:18 GMT
Content-Length: 185
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index", https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928864;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928864/YQWvqA
Replay-Nonce: 0003Lxc0agqX6kDFDmp_l_yPWfm7KI0ypz_Ur35pvIqeLH8
"type": "http-01",
2020-10-18 20:14:18,394:DEBUG:acme.client:Storing nonce: 0003Lxc0agqX6kDFDmp_l_yPWfm7KI0ypz_Ur35pvIqeLH8
2020-10-18 20:14:18,394:DEBUG:acme.client:JWS payload:
b'{\n "keyAuthorization": "3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs.ulZ63PjhLaUVfpFl6pkNXPpCJXffN4z2n7NtrZ2IXN0",\n "type": "http-01",\n "resource": "challenge"\n}'
2020-10-18 20:14:18,396:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928866/y4jlqA:
"payload": "ewogICJrZXlBdXRob3JpemF0aW9uIjogIjNaZ2hQbUpnMU83Rm9XODVkQ0J4UGpEckJ3Um5yY0FSOTlfb1NMSE1lSXMudWxaNjNQamhMYVVWZnBGbDZwa05YUHBDSlhmZk40ejJuN050cloySVhOMCIsCiAgInR5cGUiOiAiaHR0cC0wMSIsCiAgInJlc291cmNlIjogImNoYWxsZW5nZSIKfQ",
"signature": "jyrYZhqOJNghTnAhuhbUBB9kq_LA9PRjNa084m7Md78lA1tSHZnvy5uT0mog99m3t99U9uqMOErtnvnKA80zD828BOAffd1Mo88xbl6yB37wTlO4tjZJDRxYOxdSChhEQS5F5Ojlz79QmMLzejhjHnwgKD2QSpN73wxQQaZ8kMLWALs1ENxFQDK1A9eui_U8hMmu6yKHRR_wblyAXS16GLcK1k4-As8yGHzsAGAnjpr5-V32Fz0H2IxMOJwK5xhRcjQSEu-uUpwfxSyPI_wSvNWR8TL0oTLnux0MHnzgUEc2BhQuAFfkJCaLFJH7n8liO_RaijnlDLd9Q8o7FkCZgw",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwM0x4YzBhZ3FYNmtERkRtcF9sX3lQV2ZtN0tJMHlwel9VcjM1cHZJcWVMSDgiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsLXYzLzc5ODM5Mjg4NjYveTRqbHFBIiwgImtpZCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0LzY5NDg1MjM0In0"
2020-10-18 20:14:18,454:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/7983928866/y4jlqA HTTP/1.1" 200 185
2020-10-18 20:14:18,455:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 185
Link: https://acme-v02.api.letsencrypt.org/directory;rel="index", https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928866;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/7983928866/y4jlqA
Replay-Nonce: 0002Nk8zviY_meBNdm-dqKjHh8N2mQxCg-8DPROYAjWJaqg
"type": "http-01",
2020-10-18 20:14:18,455:DEBUG:acme.client:Storing nonce: 0002Nk8zviY_meBNdm-dqKjHh8N2mQxCg-8DPROYAjWJaqg
2020-10-18 20:14:21,458:DEBUG:acme.client:JWS payload:
b''
2020-10-18 20:14:21,460:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928864:
"payload": "",
"signature": "CzmujLkPHAt_aVFDBFnImDuT48L3Z3QoXltmOfSi-ZaMb0bfL0QpF4h6yZJPEyIbHG9PPBSfreG0rPyqBZx84qnIUsl22taiJHhW6Bspzg_ObU6DfuABfuKBQ513arpzVr3algSNSQlIrGYUavDHEkOl2Q2bHbgnL3HWbUt459Az2JdtKc6hJ5_G65HBeXeXMkedmH8900acAEgh5wBknxAJdHmpeY25mLTd7yoyVrSMKhp6G5hzRd7ilML1mpHCg7I6EzoV83n-WEW6Uizm-oE6b1P_FUducjKDifVXn2F8KyylzTpt7vcISkNj_7UHlEVHS5mcQ1aisfXAC2JNpA",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwMk5rOHp2aVlfbWVCTmRtLWRxS2pIaDhOMm1ReENnLThEUFJPWUFqV0phcWciLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzc5ODM5Mjg4NjQiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNjk0ODUyMzQifQ"
2020-10-18 20:14:21,523:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/7983928864 HTTP/1.1" 200 1304
2020-10-18 20:14:21,524:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 18 Oct 2020 20:14:21 GMT
Content-Length: 1304
Replay-Nonce: 0002VHcUUG7RELdIcJ3awPjMk7wosIsc-SkCrm0St5kPNlI
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:unauthorized",
"detail": "Invalid response from http://reseautage.com/.well-known/acme-challenge/esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc [2607:f748:1301:0:184:107:112:55]: "\u003c!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\"\u003e\n\u003chtml\u003e\u003chead\u003e\n\u003ctitle\u003e404 Not Found\u003c/title\u003e\n\u003c/head\u003e\u003cbody\u003e\n\u003ch1\u003eNot Found\u003c/h1\u003e\n\u003cp"",
"status": 403
"token": "esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc",
"validationRecord": [
"url": "http://reseautage.com/.well-known/acme-challenge/esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc",
"hostname": "reseautage.com",
"port": "80",
"addressesResolved": [
"165.227.33.173",
"2607:f748:1301:0:184:107:112:55"
"addressUsed": "2607:f748:1301:0:184:107:112:55"
2020-10-18 20:14:21,524:DEBUG:acme.client:Storing nonce: 0002VHcUUG7RELdIcJ3awPjMk7wosIsc-SkCrm0St5kPNlI
2020-10-18 20:14:21,526:DEBUG:acme.client:JWS payload:
b''
2020-10-18 20:14:21,528:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/7983928866:
"payload": "",
"signature": "HLaUBg1Vv9FXDtGsDMVhtEy8JyqTeljMXHyk8EevLT2lkGi1jjLuIXejulKP56SzdE6rvx56A3zeHLsc8vgewcv9qQfKe_UqiMWG7DtbMrJB_XGL0i3gBAt8yQPRICnOJQjUCnNkoHDzWQk_gMhDQzOJQ900VL70N5GafR226ZitA6rQVxckzPdBQ0-NUqxnjg-QMZnBMcBRdWjPblDRrEKuUPOPFUwCov4M6PgyD9YIDROdJwFq7aNTlbudzmyWXI3FoCho_WaZtYSTgA1WQzP7bdLXcbVegALmoMKAmE3SusuYdH2XmyVAfeO4uRT4FGRNbDLf_PQPOj9s4ueoew",
"protected": "eyJhbGciOiAiUlMyNTYiLCAibm9uY2UiOiAiMDAwMlZIY1VVRzdSRUxkSWNKM2F3UGpNazd3b3NJc2MtU2tDcm0wU3Q1a1BObEkiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LXYzLzc5ODM5Mjg4NjYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvNjk0ODUyMzQifQ"
2020-10-18 20:14:21,581:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/7983928866 HTTP/1.1" 200 1320
2020-10-18 20:14:21,582:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 1320
Replay-Nonce: 0003YmBmD1hmpJAytAWjbV1PJqdM_MXMmdIs8HcnZA2iqes
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"error": {
"detail": "Invalid response from http://www.reseautage.com/.well-known/acme-challenge/3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs [2607:f748:1301:0:184:107:112:55]: "\u003c!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\"\u003e\n\u003chtml\u003e\u003chead\u003e\n\u003ctitle\u003e404 Not Found\u003c/title\u003e\n\u003c/head\u003e\u003cbody\u003e\n\u003ch1\u003eNot Found\u003c/h1\u003e\n\u003cp"",
"status": 403
"token": "3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs",
"url": "http://www.reseautage.com/.well-known/acme-challenge/3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs",
"hostname": "www.reseautage.com",
"port": "80",
"165.227.33.173",
2020-10-18 20:14:21,582:DEBUG:acme.client:Storing nonce: 0003YmBmD1hmpJAytAWjbV1PJqdM_MXMmdIs8HcnZA2iqes
2020-10-18 20:14:21,583:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: www.reseautage.com
Detail: Invalid response from http://www.reseautage.com/.well-known/acme-challenge/3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs [2607:f748:1301:0:184:107:112:55]: "\n\n404 Not Found\n\n
Not Found
\n<p"Domain: reseautage.com
Detail: Invalid response from http://reseautage.com/.well-known/acme-challenge/esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc [2607:f748:1301:0:184:107:112:55]: "\n\n404 Not Found\n\n
Not Found
\n<p"To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
2020-10-18 20:14:21,584:DEBUG:certbot.error_handler:Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 82, in handle_authorizations
self._respond(aauthzrs, resp, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 168, in _respond
self._poll_challenges(aauthzrs, chall_update, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 239, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
certbot.errors.FailedChallenges: Failed authorization procedure. www.reseautage.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.reseautage.com/.well-known/acme-challenge/3ZghPmJg1O7FoW85dCBxPjDrBwRnrcAR99_oSLHMeIs [2607:f748:1301:0:184:107:112:55]: "\n\n404 Not Found\n\n
Not Found
\n<p", reseautage.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://reseautage.com/.well-known/acme-challenge/esrcYogxSpSCo0d8EC_rIqBePyTXuyKrUkOmeq8KXUc [2607:f748:1301:0:184:107:112:55]: "\n\n404 Not Found\n\nNot Found
\n<p"2020-10-18 20:14:21,584:DEBUG:certbot.error_handler:Calling registered functions
2020-10-18 20:14:21,584:INFO:certbot.auth_handler:Cleaning up challenges
2020-10-18 20:14:22,679:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1119, in run
certname, lineage)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 121, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/client.py", line 410, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 353, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 389, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
