Nginx 1.22.0 Certbot 1.32.2
I can't access HTTPS or port 443 on my webpage from the internet or even another machine on my LAN, even though port 443 is open and listening on Ubuntu and I can even access the webpage at localhost. Port 80/HTTP works fine from anywhere. Nothing is wrong when I run "sudo service nginx status." Nothing else is using 443 when I use netstat. Any ideas?
_az
January 12, 2023, 1:35am
2
The output of this command would be a good start to understanding why nginx isn't listening on HTTPS:
sudo nginx -T
Netstat says it's listening, but there's probably something I'm missing. Here's the output:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POOD LE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip2.conf:
load_module modules/ngx_http_geoip2_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip2.conf:
load_module modules/ngx_stream_geoip2_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/avif avif;
image/png png;
image/svg+xml svg svgz;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.oasis.opendocument.graphics odg;
application/vnd.oasis.opendocument.presentation odp;
application/vnd.oasis.opendocument.spreadsheet ods;
application/vnd.oasis.opendocument.text odt;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.wordprocessingml.document d ocx;
application/vnd.wap.wmlc wmlc;
application/wasm wasm;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
# SSL configuration
#listen 443 ssl default_server;
#listen [::]:443 ssl default_server;
root /var/www/html;
server_name duckroll.epicgamer.org;
root /var/www/html;
index index.html index.htm;
ssi on;
if ($request_uri ~ ^/(.*)\.html(\?|$)) {
return 302 /$1;
try_files $uri $uri.html $uri/ =404;
location /autosaul {
alias /var/www/html/autosaul;
try_files $uri $uri/ @autosaul;
location @autosaul {
rewrite /autosaul/(.*)$ /autosaul/info.html?/$1 last;
error_page 404 /404.html;
location = /404.html {
root /var/www/html;
internal;
error_page 403 /403.html;
location = /403.html {
root /var/www/html;
internal;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /var/www/html;
internal;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
listen [::]:443 ssl;
ssl_certificate /etc/letsencrypt/live/duckroll.epicgamer.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/duckroll.epicgamer.org/privkey.pem ; # managed by Certbot
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
if ($host = duckroll.epicgamer.org) {
} # managed by Certbot
listen 80 default_server;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file. Contents are based on https://ssl-config.mozilla.org
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECD SA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:E CDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
# configuration file /etc/nginx/sites-enabled/duckroll:
listen 80;
listen [::]:80;
server_name example.ubuntu.com;
root /var/www/duckroll/;
index index.html;
autoindex on;
autoindex_exact_size on;
I guess it'd be a firewall: nftables?
_az
January 12, 2023, 2:27am
5
Yeah, looks like a firewall issue to me.
If you run something locally like:
curl -I --resolve duckroll.epicgamer.org:443:127.0.0.1 https://duckroll.epicgamer.org
I bet it will work.
that didn't work, it returned curl: (49) Couldn't parse CURLOPT_RESOLVE entry 'duckroll.epicgamer.org:127.0.0.1:443' What is the command supposed to do?
_az
January 12, 2023, 2:29am
7
Sorry, that was before I edited the command to fix a mistake. Try what it says now.
Thanks, it worked now
Server: nginx/1.22.0 (Ubuntu)
Date: Thu, 12 Jan 2023 02:30:25 GMT
Content-Type: text/html
_az
January 12, 2023, 2:33am
9
Right. So it means that nginx is listening on port 443, and you can access it locally.
So I'd look at:
Your router/modem to see whether a port forwarding rule has been set up for port 443 TCP.
ufw status
Whether Charter are blocking port 443 on your service.
I can't even access HTTPS from a machine on the same LAN, so I don't think it's a router issue, but there is a rule set up for 443.
UFW has a rule for Nginx HTTP and Nginx HTTPS both allowed, and Nginx is actively listening when running netstat.
If charter is something you install separately like from apt, then I haven't installed it. If it is built into Ubuntu, what can I do to check if it is blocking 443?
_az
January 12, 2023, 2:44am
12
Mmm, sometimes routers suck at loopback NAT and fail to create the connection when you try to connect to the WAN IP address from inside the LAN.
I think one more thing worth checking is whether you can try the curl --resolve trick from another machine on your LAN, substituting 127.0.0.1 for the LAN IP address of your nginx server.
Edit: if you tried LAN IP already and it's not working, then it really seems that the blame is on a local firewall like ufw.
rg305
14
did it ever work?
If so, when did this problem start?
Sorry, I should have specified that I was accessing it from the Lan IP.
Never worked. I'm trying to set up my website, but I ran into this roadblock and have been trying to fix it myself. I don't know too much about Nginx, so I wasn't able to on my own, so I came here.
rg305
January 12, 2023, 2:47am
17
DUCKONAROLL:
Never worked.
OK.
Please show:
netstat -pant | grep 443 | grep -i listen
_az
18
Maybe the full output of
sudo iptables-save
would help as well. To see whether ufw is colliding with some other rules that might be blocking port 443.
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 4767/nginx: master
tcp6 0 0 :::443 :::* LISTEN 4767/nginx: master
Curl was unable to connect from my Windows machine. I'll try this (on the Ubuntu machine)
