Hello,
I’m trying to deploy a Flask app using nginx server. This server is hosted on one of my computers with an ubuntu system and using my internet connexion.
I managed to deploy the app and access it via my local network but not with others network. In order to do so, I tried to configure my box to allow remote access which is possible only through the port 4430.
Therefore I can pass the following test with success (using the port 4430): https://canyouseeme.org/
My nginx configuration is the following one:
listen 80;
listen [::]:80;
root /var/www/domain.app/html;
server_name domain.app www.domain.app;
try_files $uri $uri/ =404;
The app is still not accessible from others network when trying domain.app:4430 and I’m a bit confused about the manipulation needed in order to solve this issue.
I tried to change the nginx configuration file with port 4430 instead of 80 -> not working
I get “your connexion is not secure … NET_CERT_AUTHORITHY_INVALID”
I also tried to add a Self-signed SSL Certificate for Nginx using the following command:
sudo certbot --nginx -d domain.app -d www.domain.app
but I then get: “Timeout during connect (likely firewall problem)”
I’m quite new to that topic and any help would be very appreciated.
