Trying to understand. First steps
eticorp.us
don’t know what commands to run
so i got no output, of course
Apache
Web hosting service
'm using a control panel to manage my site (no, or provide the name and version of the control panel):
cPanel, but w/ LE connection disabled
not using certbot.
i have experience using cPanel to create private and public keys. i have been able to get keys via SSLForFree using a browser, FileZilla and or cPanel.
Is it possible to use LE this way? it sure would make life easy.
Hi @PeterPetropoulos,
If you can log into a root shell and you’re allowed to install software, you may be able to install a Let’s Encrypt client application.
Did your hosting provider install cPanel for you but deliberately disable the Let’s Encrypt feature? Is the hosting provider trying to sell you certificates via another route?
I would like to ping @_az because he’s an expert on cPanel Let’s Encrypt integration.
checking your domain you use already Cloudflare - https://check-your-website.server-daten.de/?q=eticorp.us
So you must have a working certificate. The internal Cloudflare solution is enough.
But critical: You have a loop
https://www.eticorp.us/ -> https://www.eticorp.us/
you should fix. And one critical content error:
file:///C:/NetObjects Fusion MX/NetObjects System/rollover.js
can't work, file:///C:/ isn't public visible.
thanks for responding so quickly.
  1. cPanel gives me access to the root directory.
  2. yes, the host provider deliberately disabled LE, as it’s an income stream to the tune of $75 / site / year, and i have 8 domains.
  3. so, the key is to be able to install software at the host provider, not just text files? i’d need to run certbot from host provider? i cannot get my local machine between the host and LE to get this accomplished?
Is SSLForFree.com a safe, secure alternative to LE? I’ve been able to get certs from them with ease.
thanks for your response.
yes, i have a working cert from SSLForFree, expiring in a few days. i have been told that SSLForFree is not safe. they are easy and quick. are they safe?
i’m not sure about the loop. i think the webhost did that, perhaps as a transition from http to https, but i am not sure. will check that with the provider this morning.
i do not understand the reference to Cloudflare. i see them in the host’s interface, cPanel, etc. is that something easy i should take advantage of?
No, sslforfree.com is a web-based front-end to LE. It takes the place of client software you should be running on your server.
AFAIK, they're entirely safe (as is zerossl.com, another site that does the same basic thing). The problem is that they're really doing the opposite of what Let's Encrypt is designed to do, which is automated issuance and renewal.
Yes. Let's Encrypt will give you a free cert that's valid for 90 days. That means you must renew it (at least) every 90 days (but ~60 days is the more common recommendation). It is intended that this be done automatically, which means by software. If your host doesn't allow you to install client software in your system, and has deliberately locked out cPanel's ability to get you a cert, I'd think it's time to move to a less user-hostile hosting provider.
The CT-logs don't show a Letsencrypt certificate. So you can't have a certificate from SSLForFree.
Your main domain uses a Comodo-certificate:
CN=eticorp.us, OU=PositiveSSL,
OU="Hosted by HOSTING SERVICES, INC.", OU=Domain Control Validated
	12.12.2018
	13.12.2019
expires in 34 days	eticorp.us, www.eticorp.us - 2 entries
Check https://www.eticorp.us/ in your browser. Do you see content?
You use Cloudflare. That requires a working certificate -> that's your Comodo certificate.
I answered some of the initial questions quickly, but not accurately, and have made a botch of it. My main site is eticorp.us, for which the host procured a free (to me) cert. So that 's where the Clouflare comes in. I now understand that I need to ask the question in a different way. Will repost with more accuracy. Thanks to you all. I’ll start this over.
I set up the whole question wrong to start with.
eticorp.us is my main domain at Westhost.com, where the host set up a
certificate as part of the subscription fee.
I have half a dozen or so other domains where I need additional certs
which I procured thru SSLForFree, one being LicenseManager.us.
I’m not sure about the http > https loop business, but will contact
Westhost about that.
I have closed this topic and opened a new one with more accurate info (I
hope, eh?).
Thanks again!
forgot the last question.
yes, https://eticorp.us works from my browsers.
Read the output of https://check-your-website.server-daten.de/?q=eticorp.us
eticorp.us works, but https://www.eticorp.us has a loop.
You can't test that with your browser -> there is too much caching.
How do I fix that, please?
You have created these redirects. So find these (there are a lot of possible places) and remove these.
