Trouble with authorization process
holi.se
sudo ~/certbot-auto --apache
1: holi.se
2: bandy.holi.se
3: bugger.holi.se
4: mskitchen.holi.se
5: share.holi.se
tls-sni-01 challenge for holi.se
Failed authorization procedure. holi.se (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
   Domain: holi.se
   Type:   connection
   Detail: Timeout
Apache webserver 2.2.22
Distributor ID: Debian
Description: Debian GNU/Linux 7.11 (wheezy)
Release: 7.11
Codename: wheezy
3.2.0-4-686-pae
DNS registered by Loopia (https://www.loopia.se/), pointing to own server
Yes
Accessible with both root shell through putty and webmin.
Other information:
I tried disabling the firewall but with no change.
Let me know if I can rpovide any other useful information!
Thanks!
I finally realize what I was doing wrong with my firewall and got it working. Is ther any way to mark a thread as resolved?
Selecting a post as the solution like you've done is the best way. Thanks!
