My domain is: dashboard.eliftruck.com
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/dashboard.eliftruck.com.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,)
Attempting to renew cert (dashboard.eliftruck.com) from /etc/letsencrypt/renewal/dashboard.eliftruck.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,). Skipping.
/etc/letsencrypt/live/dashboard.eliftruck.com/fullchain.pem (failure)
My web server is (include version): Apache/2.4.18 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04.3 LTS
My hosting provider, if applicable, is: Digital Ocean
Hi There,
So initially I setup by my with a manual cert from Let’s Encrypt…because at the time there were DNS issues. So right now I’m using a manual cert from Let’s Encrypt and it works great but will expire on April. I want to switch to a regular cert, so I can do automated renewals (and not renew manually every 3 months).
I tried the renew tool (see above) and basically it complained that I was using a manual cert so this wouldn’t be possible?
So that is fine…I would like to switch to a non-manual cert. I tried entering this into the command line:
sudo certbot --apache -d dashboard.eliftruck.com -d elift.freshinup.com
I entered 1 & 1 for the options. It congratulated me on creating the certs…but my cert is still due on April and when I try to do auto-renew it still complains I have a manual cert.
Thanks in advance for any help.
