Renewal Problem
Please help... -Mark
 **tu-initial-training.att.com**
 **sudo certbot renew**
Processing /etc/letsencrypt/renewal/tu-initial-training.att.com.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',)
Attempting to renew cert (tu-initial-training.att.com) from /etc/letsencrypt/renewal/tu-initial-training.att.com.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',). Skipping.
/etc/letsencrypt/live/tu-initial-training.att.com/fullchain.pem (failure)
 httpd -v
 Server version: Apache/2.4.46 ()
 uname -srm
 Linux 4.14.203-156.332.amzn2.x86_64 x86_64
 AWS
 Yes
 No
 certbot 1.9.0
You've used the manual plugin for the initial issuance of the certificate. The certbot renew command expects no user input. However, manual user input actually is required for the manual plugin if no --manual-auth-hook is provided. So that won't work.
So you have two options:
  • use the same command you used initially to get the certificate in stead of the certbot renew command, so you can, again (as you're going to be doing every 60 days......) manually provide the challanges;
  • build an authenticator script and provide it to certbot with --manual-auth-hook so you can automate renewal and don't have to do anything manually any longer.
Thanks Osiris...
Is redoing the initial issuance without the 'manual' plugin an implied third option?
Writing an authenticator script looks pretty challenging.
Redoing the DNS txt record every 60 days is not sustainable within my org.
-Mark
Tried unsuccessfully using the auto-renew instructions here:
(https://onepagezen.com/letsencrypt-auto-renew-certbot-apache)
[ec2-user@ip-172-31-45-58 html]$ sudo -i
[root@ip-172-31-45-58 ~]# cd /etc/letsencrypt/ && ./certbot-auto renew --dry-run && /etc/init.d/apache2 restart
Skipping bootstrap because certbot-auto is deprecated on this system.
./certbot-auto has insecure permissions!
To learn how to fix them, visit Certbot-auto deployment best practices
Your system is not supported by certbot-auto anymore.
Certbot cannot be installed.
Please visit https://certbot.eff.org/ to check for other alternatives.
It looks like it worked to just use 'certbot --apache'...?
[root@ip-172-31-45-58 letsencrypt]# certbot --apache
1: tu-initial-training.att.com
http-01 challenge for tu-initial-training.att.com
Deploying Certificate to VirtualHost /etc/httpd/conf.d/ssl.conf
Enhancement redirect was already set.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains:
https://tu-initial-training.att.com
    /etc/letsencrypt/live/tu-initial-training.att.com/privkey.pem
    Your cert will expire on 2021-05-02. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
    Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
That is almost always preferred if you don't need a wildcard certificate. (By Let's Encrypt policy, wildcard certificates require the DNS verification method, where you have to change a DNS record, while non-wildcard certificates don't. That means certbot --apache is able to be much more automated than certbot --manual, but the former doesn't work for requesting a wildcard.)
The certbot-auto script has been deprecated. Please don't use it in the future again. Better still, remove the wrapper script and continue to use the certbot like you did later on.
Ok, thanks Schoen and Osiris....
