Doesn’t matter, isn’t a public site
certbot renew
Processing /etc/letsencrypt/renewal/domain.conf
Cert is due for renewal, auto-renewing... Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration. The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',) Attempting to renew cert (domain) from /etc/letsencrypt/renewal/domain.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration. The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.',). Skipping. All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/domain/fullchain.pem (failure)
Apache 2.4.29
Ubuntu 18
no
or certbot-auto --version
if you’re using Certbot):
certbot 0.31.0
I have the below in a a cron job that runs every 80 days:
/usr/bin/certbot renew
this month was the first time I had to renew, and saw the cron output. I guess I am needing help with auth-hooks? Additionally, this is all just to sync iPhones to a local cal/cardav server, so none of this is public. Is there a better method or a way to actually non-interactively auto-renew? Thank you.
