My domain is: xxxxxx.nl
I ran this command: sudo certbot renew
root@ext:/home/user# sudo certbot renew
Processing /etc/letsencrypt/renewal/s01.xxxxxxx.nl.conf
Could not choose appropriate plugin: The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘There has been an error in parsing the file /etc/apache2/sites-enabled/traccar.conf on line 23: Syntax error’,)
Attempting to renew cert (s01.echotech.nl) from /etc/letsencrypt/renewal/s01.xxxxxxx.nl.conf produced an unexpected error: The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘There has been an error in parsing the file /etc/apache2/sites-enabled/traccar.conf on line 23: Syntax error’,). Skipping.
** /etc/letsencrypt/live/s01.xxxxxxx.nl/fullchain.pem (failure)**
** /etc/letsencrypt/live/s01.xxxxxxxx.nl/fullchain.pem (failure)**
The operating system my web server runs on is (include version): Ubuntu 18.04.2 LTS
or certbot-auto --version
if you’re using Certbot): certbot 0.31.0
Our webserver is redirected from port 80 to 443 in /etc/apache2/sites-enabled/traccar.conf
Hope somebody knows what i have to change to get de auto renewal working again.
Thanks!
