Trouble renewing SSL cert
My domain is: https://etal.live
I ran this command: sudo certbot renew
/var/log/letsencrypt/letsencrypt.log- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Processing /etc/letsencrypt/renewal/etal.live.conf- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -Cert is due for renewal, auto-renewing...Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.')Attempting to renew cert (etal.live) from /etc/letsencrypt/renewal/etal.live.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.'). Skipping.All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/etal.live/fullchain.pem (failure)- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/etal.live/fullchain.pem (failure)
My web server is (include version): apache
The operating system my web server runs on is (include version): debian
My hosting provider, if applicable, is: AWS Lightsail
0.31.0
We should have a look at this file:
It turns out you have to do something different in AWS LightSail:
sudo /opt/bitnami/ctlscript.sh stop
sudo /opt/bitnami/letsencrypt/lego --tls --email="<EMAIL>" --domains="<DOMAIN>" --path="/opt/bitnami/letsencrypt" renew --days 90
sudo /opt/bitnami/ctlscript.sh start
Welcome Back to the Let's Encrypt Community, Bill :slightly_smiling_face:
A couple of notes...
  • You shouldn't be using certbot with Bitnami. The appropriate process can be found in the official Amazon documentation.
  • You cannot use certbot renew with the manual authenticator without supplying hook scripts to setup and cleanup the challenges. More information can be found in the certbot user guide.
I'm running NGINX as the server for JITSI,
Did you try using the bncert tool instead of lego as mentioned in the instructions I gave?
sudo /opt/bitnami/bncert-tool
That wouldn't work. I was able to use the lego method after stopping NGNIX first, but thanks for the suggestion:
sudo /opt/bitnami/letsencrypt/lego --tls --email="<EMAIL" --domains=<DOMAIN>" --path="/opt/bitnami/letsencrypt" renew --days 90
