Trouble issues a certificate via cpanel
My domain is: http://www.hbsring.co.uk
I ran this command: Attempted to issue via cpanel
The operating system my web server runs on is (include version): Litespeed
My hosting provider, if applicable, is: Smart Hosting (https://www.bestwebhosting.co.uk/)
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel
I have created lots of LetsEncrypt certificates via cpanel but this one is not working as per the attached capture
I am not the DNS holder, that is managed by another party but A records have been amended to divert web traffic to me for displaying the website, it is on that hosting space I am attempting to issue the cert.
Could this be that the DNS changes all need time to settle or do I need to add a TXT record at the DNS for authenticating the cert issuing?
Any help would be great, thanks
The 3 domains/subdomains you are trying to issue certificates for, all have different IP addresses - only www. actually points to your cPanel server:
www.hbsring.co.uk.      86245   IN      A       77.72.0.78
hbsring.co.uk.              86399   IN      A       62.233.121.75
mail.hbsring.co.uk.     86399   IN      A       84.22.161.135
It’s best to ensure that your base domain and www subdomain point to the same place.
Whether you update mail. to the same place depends on how you’re setup, but you can always simply uncheck that domain in the Let’s Encrypt interface when going to issue your certificate.
