My domain is: www.basrobben.com
I ran this command: sudo certbot certificates
Found the following certs:
Certificate Name: www.basrobben.com
Domains: www.basrobben.com
Expiry Date: 2020-11-05 08:06:54+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.basrobben.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.basrobben.com/privkey.pem
My web server is (include version): Apache/2.4.38 (Raspbian)
The operating system my web server runs on is (include version): Raspbian Debian 10
When trying to connect to my site, www.basrobben.com, it will autoconnect to the http version and work fine. But after changing it to https, it does not work anymore.
I already found out that the certificate of the domain is not assigned by certbot, but instead, by “root.home” (see image for reference).
Is there some way to somehow force the domain to use the certificate provided by certbot?
I am pretty new to all of this stuff, so please bear with me.
