Cannot connect via http after running certbot for apache
Hope someone can help me here…
I have a raspberry pi running Apache. I have two domain names pointing to the IP address of the box. I ran certbot to configure one of the domain names for https - chose the Easy option so I could connect to both http and https (I figured I could change this manually later on).
After running I can now connect to https. But I can’t connect to http - browser just times out. Nothing in apache’s access.log or error.log.
Weird thing is, the other domain name (connecting to the same box, same apache config, etc.) still works for http - so I’m thinking it can’t be a firewall problem.
Can’t see anything in apache config files that would make it behave in this way. As an experiment I tried removing the ssl config from sites-available - but that just stopped https working and still http didn’t work.
I’m clearly missing something here but can’t for the life of me figure out what it is.
Have you setup a redirect for the port 80 site to redirect to port 443 ?? What’s your domain name ??
Your Apache vhost conf file should look something like this.
<IfModule mod_ssl.c>
<VirtualHost *:443>
DocumentRoot /var/www/mysite/
ServerName mysite.com
ServerAlias www.mysite.com
ErrorLog ${APACHE_LOG_DIR}/mysite-error.log
CustomLog ${APACHE_LOG_DIR}/mysite-access.log
<Directory "/var/www/mysite/">
Options +Includes
Options +FollowSymLinks -Indexes
....... OTHER STUFF HERE
</Directory>
SSLCertificateFile /etc/letsencrypt/live/mysite.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mysite.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/mysite.com/chain.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
        RewriteEngine On
        RewriteCond %{HTTPS} off
        RewriteCond %{HTTP_HOST} ^(?:www\.)?(.*)$ [NC]
        RewriteRule (.*) https://mysite.com%{REQUEST_URI} [END,QSA,R=permanent]
</VirtualHost>
Sorted! Thanks very much. The bit that I was missing was the VirtualHost *:80 at the bottom. I was expecting the old hosts file that had this bit in to still work. Once I added it to the new one that certbot created, it worked.
