Too many certificates already issued for exact set of domains
When requesting certificate, the following message shows due to incorrect operation:
Requesting Certificate
Unexpected error
ACME Server Returned:
“type”: “urn:acme:error:rateLimited”,
“detail”: “Error creating new cert :: too many certificates already issued for exact set of domains: sa.bhz.com.cn: see https://letsencrypt.org/docs/rate-limits/”,
“status”: 429
My question is:
For this domain sa.bhz.com.cn, when can I apply for a new certificate again?
Is there any way I can delete the existing certificate?
Thanks a lot.
In 7 days.
If you want, you can add a second subdomain to the certificate to circumvent the rate limit. But it's not a sustainable workaround.
Hi @Snap
you have already created 5 certificates ( https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=p:c2EuYmh6LmNvbS5jbjpmYWxzZTpmYWxzZTo6RUFFPQ&cert_search=include_expired:false;include_subdomains:false;domain:sa.bhz.com.cn&lu=cert_search_cert lists 5 pre- and 5 leaf certificates).
What's the problem to use one of these certificates the next 60 - 85 days, then create a new?
Deleting or revoking doesn't reset the rate limit.
When generating these certificates, incorrect username and password were entered, thus these certificates had not been successfully created. Thanks.
As far as Let’s Encrypt goes, they were successfully created.
What were the usernames and passwords for?
Are you sure your software didn’t save anything? Not even the private keys?
I uploaded a screenshot to show where LetsEncrypt asked me to enter username and password and also the information when I entered the wrong password. Please help check what the username and password is for and if there is anything saved.
Thanks a lot.
That appears to be creating a scheduled task - which would run with the credentials provided.
Your first screenshot shows, that the certificates are created and saved.
But I’m wondering that they are saved in “My”, not in “Webhosting”.
To create a task, you don’t use the Sql Server database sa - account. You must use a windows administrator account. sa is not a windows account.
