Ubuntu 16.04
DigitalOcean
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.31.0
hey, I dont want to issue another one. I am fairly new at this and I deleted my files as well. I dont have the pem keys as well. Is there any way I am recover them please?
If you have deleted the files they cannot be recovered. – Well the public key can but the private key is only ever stored on your server. You will be able to create additional certificates on 2019-10-29 at 08:15:48.
You should not delete certificates, always reuse them unless they are expired.
You can read more about rate limits. You have hit the "Duplicate Certificate" limit of 5 per week, but you can avoid that by changing the set of domains you request certificate for (e.g., add a new subdomain). Note that this still would be subject to "Certificates per Registered Domain" limit, which is 50 per week. It's best not to exceed the 50 certs per week limit.
