Too many certificates already issued for exact set of domains
Hallo
for https://crt.sh/?q=mail.tvnl.eu
server ubuntu 18.04
I reinstalled the Ubuntu 18.04 server
I did not save the certificates before reinstalling
so
now I don’t have any certificate on the server in the directory /etc/letsencrypt/
I want to issue another certificate
the existing ones are for Apache2, and now I use nginx
I used the command
#certbot --nginx
1: autoconfig.tvnl.eu
2: mail.tvnl.eu
blank to select all options shown (Enter ‘c’ to cancel): 2
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: mail.tvnl.eu: see https://letsencrypt.org/docs/rate-limits/
my question is:
  1. how can i delete all certificates from https://crt.sh/?q=mail.tvnl.eu because they are for apache2 and now I use nginx
  2. how can i issue a new certificate for nginx
I’m waiting for answers
thank you
certbot --version
certbot 0.31.0
nginx -v
nginx version: nginx/1.14.0 (Ubuntu)
system ubuntu 18.04 64x
certbot certonly --dry-run -d mail.tvnl.eu
1: Nginx Web Server plugin (nginx)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): 1
Plugins selected: Authenticator nginx, Installer None
  • The dry run was successful.
but I can't find my location
You cannot undo certificates. Deleting or revoking them will not reset your rate limits.
You'll have to wait another 12 hours before this certificate can be issued again.
In future, it may help to save your certificates if you plan to reinstall your server again.
ok
I will try tomorrow
and I will come back with an answer
thanks for everything
12 hours have passed
certbot --nginx -d mail.tvnl.eu
and nothing no solution
:frowning:
with this command I solved the problem
all a certificate and ready
certbot --nginx -d tvnl.eu -d www.tvnl.eu -d mail.tvnl.eu
Your site is now secure and your cert expires 5 Oct, 2020. :slightly_smiling_face:
I only use this certificate
crt.sh ID Logged At ⇧ Not Before Not After Matching Identities Issuer Name
3055014140 2020-07-07 2020-07-07 2020-10-05 mail.tvnl.eu C=US, O=Let’s Encrypt, CN=Let’s Encrypt Authority X3
how can I cancel the rest of the certificates?
You can't, and there's no reason to. If the public keys are destroyed, nobody can use them.
correction: if the private keys are destroyed
Ack. Yes, of course. Oops.
how I destroy all the keys
I just want this key to stay
system ubuntu 18.04
nginx
If you've deleted the server instances (or deleted the certificate files from them), the private keys are destroyed--you had the only copy of them. The public keys are, as the name suggests, public. They are immutably logged and cannot be changed or removed. But they can't be used without the private keys, which you've already destroyed.
