Issue with many certificates already issued
Dear Team:
I’d like to ask you for your help. I have deleted my droplet in DigitalOcean many times latetly because I am debuging another issue that I have, so it seams that I have applied multiple times the certification with Let’s Encrypt.
I can see here I have 7 certificates Id.
https://crt.sh/?q=www.esahora.cl
I have tried to deleted them with command “sudo certbot delete” or “sudo certbot delete --cert-name esahora.cl” but I am getting “No existing certificates found.”, because all settings that could have been have been dropped, cause I have purged my droplet.
Could please let me know how could I delete certificates already created?
My domain is: www.esahora.cl
I ran this command:sudo certbot --apache
It produced this output:There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: www.esahora.cl: see https://letsencrypt.org/docs/rate-limits/
My web server is (include version): Apache/2.4.29 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04, Droplet
My hosting provider, if applicable, is:Digital Ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.31.0
Hi @felipeEnc
please read the document.
Then you read that revoking / deleting certificates doesn't reset the rate limit.
Looks like you have to wait. Never create certificates and delete these - that's always wrong.
Ah - there are some checks of your domain - https://check-your-website.server-daten.de/?q=esahora.cl#ct-logs
Let's Encrypt Authority X3 2019-10-10 2020-01-08 www.esahora.cl - 1 entries duplicate nr. 5 next Letsencrypt certificate: 2019-10-15 18:07:07
Let's Encrypt Authority X3 2019-10-10 2020-01-08 www.esahora.cl - 1 entries duplicate nr. 4
Let's Encrypt Authority X3 2019-10-08 2020-01-06 www.esahora.cl - 1 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-10-08 2020-01-06 www.esahora.cl - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-10-08 2020-01-06 www.esahora.cl - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-10-08 2020-01-06 esahora.cl - 1 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-10-08 2020-01-06 esahora.cl - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-10-07 2020-01-05 esahora.cl - 1 entries duplicate nr. 1
Let's Encrypt Authority X3 2019-09-27 2019-12-26 esahora.cl - 1 entries
Let's Encrypt Authority X3 2019-09-25 2019-12-24 esahora.cl - 1 entries
You can create one certificate with both domain names.
Then store the private and the public key, so you can use the certificate 60 - 85 days.
Thanks for your reply Juergen.
1.-About this “Then store the private and the public key, so you can use the certificate 60 - 85 days.”, it means that I should have backup up both of the .pem file that were created and after creating a new Droplet I should have import them in my new Droplet, righ?
2.-Also now I have to wait until October 15 to be able to create a new certificate.
Is this right?
