Too many attempts
My domain is: derleiti.de
i guess i had too many attempts. i wanna ask for a early reset due to webserver configuration is not complete.
Rate limits cannot be manually reset. (This is also explained in the rate limit documentation by the way.)
Hi @derleiti,
Testing and debugging are best done using the Staging Environment as the Rate Limits are much higher.
And the answers haven’t changed since your first time question.
The domain derleiti.de is being served through Cloudflare CDN.
Check that you're not geographically blocking requests and stopping Let's Encrypt from checking your domain. It will check your site at http://derleiti.de/.well-known/acme-challenge/<challenge file> so you need to allow those requests to pass through to the filesystem and not catch them with your content management system 404 page etc.
Alternatively you could change to using DNS validation (with Cloudflare) instead of http validation.
