TLS Certificate is not trusted
My website had SSL running successfully before 2 weeks. But due to some malware attack, I couldn't load my site using HTTPS. But after clearing the issues, still website is not supporting SSL. I have reinstalled the certificate but no use. When I am checking site with Sucuri site check, It show error like " TLS Certificate is not trusted"
My domain is: pharm-sol[.]com
sudo snap install core
sudo snap refresh core
sudo snap install --classic certbot
sudo certbot --apache -d pharm-sol[.]com
It produced this output: installed successfully
The operating system my web server runs on is (include version): ubuntu
certbot 2.8.0
HI @geethzz, and welcome to the LE community forum :slight_smile:
First things first:
To anyone wanting to help here:
Please note:
And:
VirusTotal - URL - bbc0ab73ff82290112ee96201c2f991138351fc349c954df1de281864c227cfb
Be very careful when accessing this site.
That out of the way...
The site is currently using a self-signed cert.
See: SSL Server Test: pharm-sol.com (Powered by Qualys SSL Labs)
What shows?:
sudo apachectl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 is a NameVirtualHost
         default server pharm-sol[.]com (/etc/apache2/sites-enabled/default-ssl.conf:2)
         port 443 namevhost pharm-sol[.]com (/etc/apache2/sites-enabled/default-ssl.conf:2)
         port 443 namevhost pharm-sol[.]com (/etc/apache2/sites-enabled/pharmsol-le-ssl.conf:2)
                 alias www.pharm-sol[.]com
*:80  is a NameVirtualHost
         default server pharm-sol[.]com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost pharm-sol[.]com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost beta.pharm-sol[.]com (/etc/apache2/sites-enabled/beta-pharmsol.conf:1)
                 alias www.beta.pharm-sol[.]com
         port 80 namevhost pharm-sol[.]com (/etc/apache2/sites-enabled/pharmsol.conf:1)
         port 80 namevhost web.pharm-sol[.]com (/etc/apache2/sites-enabled/web-pharmsol.conf:1)
                 alias www.web.pharm-sol[.]com
Note: There are links in your page that are flagged malicious!
See:
VirusTotal - URL - 7834d74515b137d55014613226441d7aa02f7c23a262c6ef8ff86c5e937ba6d1
What shows?:
certbot certificates
Found the following certs:
  Certificate Name: pharm-sol[.]com
    Serial Number: 4b2082366bcff95ddbf21d417209f3d0fcc
    Key Type: ECDSA
    Domains: pharm-sol[.]com
    Expiry Date: 2024-04-14 05:26:53+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/pharm-sol[.]com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/pharm-sol[.]com/privkey.pem
There are multiple name:port overlaps.
Two files are using pharm-sol[.]com:443:
  • /etc/apache2/sites-enabled/default-ssl.conf
  • /etc/apache2/sites-enabled/pharmsol-le-ssl.conf
Two files are using pharm-sol[.]com:80:
  • /etc/apache2/sites-enabled/000-default.conf
  • /etc/apache2/sites-enabled/pharmsol.conf
Each FQDN:PORT combination should only appear once within your configuration.
