Timeout when renewing cert
Hi. I just noticed my certificate didn’t renew automatically. Trying to renew manually I got response:
# letsencrypt renew
Processing /etc/letsencrypt/renewal/apps.ufficyo.com.conf
http-01 challenge for apps.ufficyo.com
Attempting to renew cert from /etc/letsencrypt/renewal/apps.ufficyo.com.conf produced an unexpected error: Failed authorization procedure. office.ufficyo.com (http-01): urn:acme:er
ror:connection :: The server could not connect to the client to verify the domain :: Fetching http://apps.ufficyo.com/.well-known/acme-challenge/q6X8BFQqWKs3696LIOGFjfi7M4BGedsjmiFjX7Bi83k: Timeout. Skipping
This looked very strange to me, I tried accessing the website from outside our network and works fine. If you try yourself you will get a forbidden error, but that’s expeted.
The web server is running nginx, and log showed no access attempt from outside. There’s no iptables rule or firewall blocking connections. What else could cause this timeout?
thanks
search IPV6 on these forums as the problem you are likely facing has been discussed on almost a daily basis
Andrei
indeed, temporary disabling IPv6 renewed my cert! :confused:
Will try to figure out what’s wrong
most likely reason is your IPV6 is pointing to the correct server however you have not set up a listener for IPV6 :smiley:
Andrei
what do you mean with an ipv6 listener? I do have a webserver pointing to that IP, correctly replying to requests
You may have a web server listening and replying on IPv4, but not configured to handle IPv6. This is a pretty common issue. It may be something else, but that sort of thing happens a lot.
Damn, indeed IPv6 was blocked on the firewall :man_facepalming:
