I ran this on an identical build last week using the same hardware an a clean install of debian 10 running apache2 and certbot worked. There is no firewall installed and I double checked that it wasn't installed as part of the distro. I can connect to the sites using lynx and firefox. Not sure what else to check..... I would be grateful for any suggestions how to fix this.
chenla.org, chenla.net, chenla.la
sudo certbot --apache
$ sudo certbot --apache
1: chenla.net
2: chenla.la
3: chenla.org
4: www.chenla.net
5: www.chenla.org
6: www.chenla.la
Requesting a certificate for chenla.net and 5 more domains
Domain: chenla.la
Type: connection
Detail: Fetching http://chenla.la/.well-known/acme-challenge/dgIkVhdkoZu3dRjmc8OPYrk9GWQ-4RsXN6CS65gPdH4: Timeout during connect (likely firewall problem)
Domain: chenla.net
Type: connection
Detail: Fetching http://chenla.net/.well-known/acme-challenge/1vkwpA09GYSP8PXpNRqVd4_foTb-YRWYNiquPbAAGhI: Timeout during connect (likely firewall problem)
Domain: chenla.org
Type: connection
Detail: Fetching http://chenla.org/.well-known/acme-challenge/47UJtEAuhF96INlevx85ilzlb6E1SdH1jzjpb_NLEGw: Timeout during connect (likely firewall problem)
Domain: www.chenla.la
Type: connection
Detail: Fetching http://www.chenla.la/.well-known/acme-challenge/9W6X0Xn2fkfiklfH4SqKgouXJIFLdfvvRVtgvSsm1wI: Timeout during connect (likely firewall problem)
Domain: www.chenla.net
Type: connection
Detail: Fetching http://www.chenla.net/.well-known/acme-challenge/B0-u-5U-kLTGl1QB72SSsAAsxL5pCeDFaBFlA0EqWeE: Timeout during connect (likely firewall problem)
Domain: www.chenla.org
Type: connection
Detail: Fetching http://www.chenla.org/.well-known/acme-challenge/2LiAMONaChC13fLPzVgJypkVORUJ_gK-JkvBWt4u9Ek: Timeout during connect (likely firewall problem)
╭ deerpig@hilarius:/etc/apache2/sites-available
apache2 (latest version from apt-get)
Debian 10
n/a -- self hosted with our own class C ip block.
no
or certbot-auto --version
if you're using Certbot):
certbot 1.20.0
