TImeout during connect
Hi All, I’m getting a timeout error altough it seems my nginx repsonds to outside requests
leibowitz.ddns.net
sudo acme-nginx -d leibowitz.ddns.net --debug
2020-04-30 10:14:04,929 - ERROR - leibowitz.ddns.net challenge did not pass: {u’status’: u’invalid’, u’cu’invalid’, u’validationRecord’: [{u’url’: u’http://leibowitz.ddns.net/.well-known/acme-challenge/TXXLAnKliBnjN9eAys’, u’hostname’: u’leibowitz.ddns.net’, u’addressUsed’: u’109.186.69.244’, u’port’: u’80’, u’9.186.69.244’]}], u’url’: u’https://acme-v02.api.letsencrypt.org/acme/chall-v3/4269570543/iMuwrQ’, u’tokg2YP-G4SdmUv5KliBnjN9eAys’, u’error’: {u’status’: 400, u’type’: u’urn:ietf:params:acme:error:connection’ttp://leibowitz.ddns.net/.well-known/acme-challenge/TXXLAndy_zy2a2O_1pg2YP-G4SdmUv5KliBnjN9eAys: Timeoutirewall problem)’}, u’type’: u’http-01’}], u’identifier’: {u’type’: u’dns’, u’value’: u’leibowitz.ddns.n05-07T07:13:09Z’}
nginx 1.4.6
Ubuntu 14.04
Self hosted
Yes
No
latest acme-nginx
Thanks!
Hi @adilei
if you want to create a certificate via http validation, a working port 80 is required.
Your port 80 doesn't answer. Check your firewall and router setup.
Thanks @JuergenAuer. However port 80 actually does respond for me
It doesn't answer. See your online check, ~~3 hours old - https://check-your-website.server-daten.de/?q=leibowitz.ddns.net
Timeouts checking http.
You use your internal connection.
I can see it is failing the check, however I am getting a response even from my smartphone on the mobile network, so router/firewall seems fine. Any chance this is ISP related?
If it's your WiFi, that's the same.
Online checks (like "check your website" or Letsencrypt) must be able to see your port 80 answer.
It’s not my Wifi - it’s the cellular network. Hence my confusion.
Thanks,
Adi
