Issue installing cert
My domain is: status.monetagosolutions.com
I ran this command: sudo certbot --nginx
2019-09-06 05:53:11,336:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: status.monetagosolutions.com
Type: connection
Detail: Fetching http://status.monetagosolutions.com/.well-known/acme-challenge/Vr00gbpNrsuRqyVTjBxXn2dgX-PtvQvFeFipSnzdll4: Timeout during connect (likely firewall problem)
2019-09-06 05:54:51,749:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 658
X-Frame-Options: DENY
Expires: Fri, 06 Sep 2019 05:54:51 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Fri, 06 Sep 2019 05:54:51 GMT
“keyChange”: “https://acme-v02.api.letsencrypt.org/acme/key-change”,
“meta”: {
“caaIdentities”: [
“letsencrypt.org”
2019-09-06 05:54:53,919:INFO:certbot.main:Obtaining a new certificate
2019-09-06 05:54:53,959:DEBUG:certbot.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0004_key-certbot.pem
2019-09-06 05:54:53,962:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0004_csr-certbot.pem
2019-09-06 05:54:53,962:DEBUG:acme.client:Requesting fresh nonce
2019-09-06 05:54:53,962:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2019-09-06 05:54:54,012:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 “HEAD /acme/new-nonce HTTP/1.1” 200 0
2019-09-06 05:54:54,013:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Link: https://acme-v02.api.letsencrypt.org/directory;rel=“index”
Replay-Nonce: 0101kMvatW1Td6dfjsJ8ALFg8U1ztEPOpRagOU6YxY5dTMc
Content-Length: 0
Expires: Fri, 06 Sep 2019 05:54:54 GMT
Pragma: no-cache
Date: Fri, 06 Sep 2019 05:54:54 GMT
NAME=“Ubuntu”
VERSION=“18.04.2 LTS (Bionic Beaver)”
NAME=“Ubuntu”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 18.04.2 LTS”
VERSION_ID=“18.04”
Azure
certbot 0.31.0
I have tried allowing all traffic on port 80 and then running the command " sudo certbot --nginx" but i get the same error. Can you help me fix this please
Thanks
Are you sure it was exactly the same error the last time you tried, including the Timeout during connect part?
From what I can tell, right now Let's Encrypt has no issues connecting to your server.
Hi @Eva
your server answers ( https://check-your-website.server-daten.de/?q=status.monetagosolutions.com ):
• http://status.monetagosolutions.com/
13.68.173.141 200 0.243 H
• https://status.monetagosolutions.com/
13.68.173.141 -14 10.030 T
Timeout - The operation has timed out
• http://status.monetagosolutions.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
13.68.173.141 404 0.210 A
Not Found
That looks good, checking /.well-known/acme-challenge/random-filename has the expected result http status 404 - Not Found.
Did you change something?
PS: There is no older Letsencrypt certificate.
I’m trying to install the cert for the first time now.
To add to, i was following the steps mentioned here - https://certbot.eff.org/lets-encrypt/ubuntubionic-nginx
Try it one time again:
sudo certbot --nginx -d status.monetagosolutions.com
There is no timeout visible.
http://status.monetagosolutions.com/.well-known/acme-challenge/1234
answers, so --nginx should work or should show another error message.
If that doesn't work, add -vvv to the command and share the output. Perhaps via pastebin.
Hi Juergen
I tried sudo certbot --nginx -d status.monetagosolutions.com and a cert got installed with no errors but my site is now inaccessible now. Wondering what is causing the issue
This is how my nginx config looks like :
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /usr/share/nginx/modules/*.conf;
events {
worker_connections 1024;
http {
log_format main '$remote_addr - $remote_user [$time_local] “$request” ’
'$status $body_bytes_sent “$http_referer” ’
‘"$http_user_agent" “$http_x_forwarded_for”’;
access_log  /var/log/nginx/access.log  main;
sendfile            on;
tcp_nopush          on;
tcp_nodelay         on;
keepalive_timeout   65;
types_hash_max_size 2048;
include             /etc/nginx/mime.types;
default_type        application/octet-stream;
# Load modular configuration files from the /etc/nginx/conf.d directory.
# See http://nginx.org/en/docs/ngx_core_module.html#include
# for more information.
from here
server_name mydomain; # Or whatever you want to use
root /var/www/html/Cachet/public;
index index.php;
    add_header Strict-Transport-Security max-age=15768000;
    try_files $uri /index.php$is_args$args;
location ~ \.php$ {
            include fastcgi_params;
            fastcgi_pass unix:/var/run/php/php7.2-fpm.sock;
            fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
            fastcgi_index index.php;
            fastcgi_keep_conn on;
ssl_certificate /etc/letsencrypt/live/mydomain/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mydomain/privkey.pem; # managed by Certbot
if ($host = mydomain) {
} # managed by Certbot
listen 80 default;
Rechecked your domain via https://check-your-website.server-daten.de/?q=status.monetagosolutions.com - now you have a (good) redirect http -> https:
13.68.173.141 301 https://status.monetagosolutions.com/ 0.200 A
13.68.173.141 -14 10.033 T
13.68.173.141 301 https://status.monetagosolutions.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.200 A
Visible Content: 301 Moved Permanently nginx/1.14.0 (Ubuntu)
• https://status.monetagosolutions.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de -14 10.034 T
And a new certificate:
Let's Encrypt Authority X3 2019-09-06 2019-12-05 status.monetagosolutions.com 1 entries duplicate nr. 1
So the certificate creation has worked.
Is there again a firewall? You have to allow https.
Does your port 443 work internal?
curl https://status.monetagosolutions.com/
My bad, i had not allowed traffic on port 443. Did it now and is working as expected. Thanks for your help Juergen!
Regards!
Yep, now it works. But it's a public website, so port 80 should answer. There is a timeout.
If not, the next renew doesn't work, Letsencrypt certificates are only 90 days valid. Next renew should start in 60 days, Certbot creates a cron job.
Read
I have now opened port 80 too. Thanks for the info :slight_smile:
